![]() | Home > Maintenance & Mods (L322) > Genuine 20" Stormer Alloys |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
I know that these wheels are generally used on RRSs but can also be fitted to FFRRs but can you fit different width tyres on them. Most I have seen for sale are fitted with 275 tyres but could you also fit them with 255 wdith tyres or would that cause problems? FFRR TD6 HSE
I once bought a FFRR with Stormers and 295 width tyres fitted. They were worn so I changed them to 275 which are perfect for stormers but do have a smaller rolling radius on the FFRR as Vogue pointed out. Best stick with wheels designed for the Full Fat. |
Thanks lads. I'll be following that advice when I get some new wheels. FFRR TD6 HSE
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Also the RRS 20" wheels are all incredibly easy to ding/scuff with RRS sized tyres on - in nearly 3 years of owning mine I had the full set of wheels refurbed twice while I had the winter wheels on. The winter wheels were 19" with higher profile tyres and I never managed to get them scuffed once, even when I took the car offroad on the Keilder forest drive last February! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
one of the advantages of RRS wheels is that they are 9.5j wide as opposed to the standard FFRR wheels which are 8.5j and the offset is different by 3mm so the wheels will stick out more..this aint a bad thing as the FFRR looks visually better with the wheels filling the wheel arches more than the FFRR wheels..
Can I see a picture Scarey? |
below the waist or above?... |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Someone has had your bung outa your armature big boy..... |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Sorry for the hijack. Scary what they've two White blocks above your number plate? |
does look nice scarey. I do like the stormer alloys and have seen them on other FFRR and been impressed.
towbar you mean?, its in the garage... |
amber tir3 leds rob. ![]() |
cheers greg, is that the 19'' seven spoke you're on about or the 20''......if its the 20'' then i agree they are nice [and easy to clean]. |
