Home > Maintenance & Mods (L322) > Oil Leak of some sort
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
ok so since it was a dry day today i got under the RR today to change the engine oil.. Boy it does go everywhere despite me fashioning a plastic bottle to control the flow.. but hey ho followed everyones advice and put card board under and lets say I will be sleeping in my bed tonight and not the couch.
while I was there I noticed some oil leak. it was where the transmission meets the engine. Any idea where this could be coming from?
see pic below.. am also right I thinking that there should be some kind of grommett in the hole there?
PS. the transmission pan is bone dry Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #443907 8th Jul 2017 1:03pm
CS
I don't know the source of your leak, but mine leaked gear box oil from the join between engine and gearbox, needed a new gearbox as 2 litres had been lost, so worth checking if it is that. Only Range Rovers since 1988
Post #443919 8th Jul 2017 2:41pm
scotcruz
oh dear..
I hope its not that.. I have cleaned it all up so will check the source again..
any about the hole? is that an inspection hole which needs to have a grommett or something?
can someone please check and let is know Current:
Past:
Post #443926 8th Jul 2017 3:20pm
nino_nino
Bosnia Herzegovina 2012 Range Rover Autobiography Black TDV8 Santorini Black
scotcruz if you have 4.4TDV8 than the oil leak is most probably from leaking O ring in the back of the engine. excellent tread how to fix it started by Cam-Tech-Craig.
http://www.fullfatrr.com/forum/topic35977.html
ps.
you are missing rubber grommet.
Post #443931 8th Jul 2017 4:30pm
scotcruz
cheers mate.. mines a 3.6 TDV8 but will have a read and hope it is that and not the gearbox seal.
thought it was a missing grommet. Current:
Past:
Post #443933 8th Jul 2017 4:42pm
