![]() | Home > Maintenance & Mods (L322) > TDV8 Diff and Trans oil |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
but reluctant to my VIN code and it's up for everyone to see as it shows the last search Current:
Picked up the oil from LR and changed the transfer case oil today.. Man that was satisfying.. dont think the oil had been changed since it was manufactured.
Keith A Member Since: 25 Oct 2012 Location: Sherborne, Dorset Posts: 105 ![]() ![]() ![]() |
Haven't done the front on mine yet as it's a 14mm drain plug key, which I didn't have.
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
yes the front is fiddly! i would suggest an extension and UJ on your ratchet or i used the 1/2" drive handle i got with my caravan motor mover as it has a gentle curve in it which gave enough clearance from the sub frame. Also when you crack the fill plug on the front, i used a 14 mm ratchet spanner on the allen key socket to turn it quicker and easier. My old fat fingers not so agile these days... |
cheers guys.. wish there was a video which showed the oil change as its always good to know what you are up against while u are under the car.
There are videos on you tube for diffs and trans box! Current: TDV8 (3.6) RRS HSE
I found the transfer bix ones for 3.6 TDV8 but non for front diff.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
it is worth noting, when changing differentials and transfer box oil to undo the filler plugs before draining the oil. just in case
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Good tip Nino.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
cam-tec-craig always banged on about that... |
credit where credit is due , tks. stan |
Easy to do (just done mine).
did you undo the splash bar that's infront of the drain plug? Current:
Nope. Just the undertray to come off. Current cars:
