Home > My Range Rover > range rover with problems
Page 16 of 18 <123 ... 15 161718>
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
very nice, looks nice inside to, mine is nowhere as good as that inside.
the speed sensor arrived today, I will be fitting it tomorrow, rain or no rain
i think i have stuffed up my radio now, had it working fine RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #517605 6th Jun 2019 2:08pm
knares
Sandy Choda wrote:
Try driving without the Air flow meter plugged in.
i did try that didnt seem to make much difference, i pulled it apart and it looked ok
i did the steering thing as well RR 2005 4.4 petrol
Post #517608 6th Jun 2019 2:14pm
knares
just a quick one, i reversed it back a bit to fit the wheel speed sensor
 RR 2005 4.4 petrol
Post #517664 7th Jun 2019 4:19am
knares
Sandy Choda wrote:
Try driving without the Air flow meter plugged in. I've had it before on BMW engines and it drives like a carb'd engine.
i started it this morning, it messed around as usual, when it did idle it was running rough and i remembered what you said so i puled the plug off, the revs picked up and it idled a lot better RR 2005 4.4 petrol
Post #517665 7th Jun 2019 4:25am
Sandy Choda
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Solution in my case was to replace the Air Flow Meter. When searching online try looking up the alternative part numbers. If I have the right one from LR Cat:
Land Rover - MHK000230
Bosch - 0 280 217 814
BMW - 13 62 1 433 567
Have been following your post, hope you get it sorted! Thumbs Up
Post #517678 7th Jun 2019 8:36am
knares
fitted the wheel speed sensor
canceled the faults that i could but i couldn't cancel the ABS faults
the red ABS and the other red light went out, the air suspension inactive went off
cant find where to cancel the air bag fault
went for a drive, about 20km and every thing looks good, no red lights, no air suspension inactive RR 2005 4.4 petrol
Post #517685 7th Jun 2019 11:05am
knares
Sandy Choda
tomorrow when i start it up, i will remove the plug first and see how it starts, then i will go for a run with it disconnected, i don't know if that will harm any thing RR 2005 4.4 petrol
Post #517687 7th Jun 2019 11:10am
knares
rovers price for an air flow meter $340.00 RR 2005 4.4 petrol
Post #518025 11th Jun 2019 4:30am
Sandy Choda
Try ebay/gumtree for the Bosch number 0 280 217 814 or BMW part number 13 62 1 433 567
Post #519205 21st Jun 2019 9:48am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
https://www.aliexpress.com/item/Mass-Air-F...st=ae803_4 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #519209 21st Jun 2019 10:32am
knares
thanks for the links guys
i had already ordered one, it arrived and i fitted it
it dosnt seem to have made much difference to the starting the engine
i haven't taken it for a run yet, so i will see RR 2005 4.4 petrol
Post #520480 3rd Jul 2019 12:44pm
knares
Not getting anywhere with this engine
Engine light comes on at about 1200 revs
I do know it is missing on at least one cylinder
The icarsoft unit says it missing on the right bank (bank 1), it also says it has a camshaft timing fault
The GAP tool says no engine faults, it once said it had a 0x421 fault
I haven’t been able to find out what 0x421 means and I did ask BMW
As It had the camshaft timing fault before I bought it, before I changed the timing gear, I am not sure it is the timing that is out, it may be an electrical fault or a lack of oil pressure to the right vanos
I thought I would take it to the agents and get them to diagnose the engine problems
I thought I would go to BMW, it is there engine and they would have more experience than Rover
They didn’t want to do it and advised me to go to Rover
Today I went to a Rover mob that I trust, I have dealt with them a bit before
I asked them if they could do a diagnostic test on my car
“Yes certainly, what motor has it got”
“BMW”
“Scrap it, scrap it, just scrap it”
“O”
“we won’t touch them, they are a good motor while they are going but if they are not going properly, they are scrap, I will tell you what, have a look at this one”
We went out the back, he showed me a beautiful RR, said the owner had spent $10,000 having the motor fixed and it still wasn’t running right and sold it to them for scrap
said i could have it for $4000 its a 2002
 RR 2005 4.4 petrol
Post #525062 16th Aug 2019 2:00pm
knares
its a HSE and its not licensed RR 2005 4.4 petrol
Post #525063 16th Aug 2019 2:08pm
rar110
That’s frustrating. ______________________________
Post #525186 17th Aug 2019 11:50pm
Gsxr1250dave
Vanos wont have anything todo with your problem look elseware
Post #525188 18th Aug 2019 1:13am
