![]() | Home > In Car Electronics (L322) > Electrics faults? |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
Have you checked for any moisture to the electric components? I have had gremlins recently but they were fine after a day so been lucky..
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Check for water ingress in rear quarter panels (where the amps and fuse boxes are located in the back of the car left and right sides). This is a common problem on these cars.
Alanwl Member Since: 27 May 2017 Location: Plymouth Posts: 3 ![]() ![]() ![]() |
All other problems on post aside the main one is.Came home turned off as normal no previous problems.Went to start next morning key would not turn no motor swish steering locked.Remote opened doors ok.Tried all the options fuses in and out,new battery leaving disconnected,touching cables together even pulling plug on ecu on steering column.Before I start spending on trial and error to eliminate is there any way of telling if it is definitely the column.Any help much appreciated.Other than this a lovely 2007 key in dash touchscreen TDV8 Vogue. |
Given that it's a 2007 I would get your alternator checked. |
Alan... how did you get on? Current:
Checked everywhere all dry all well plugged fitted new battery at wits end just want someone to tell me how to rule in or out spending a fortune on a steering column only to find it wasn't that |
