Home > Technical (L322) > 2010 Vogue broken |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1434 |
First thing I would suggest is to have the fault codes read as that might point you in the right direction. 2021 D350 Fifty Edition - Carpathian Grey
26th May 2017 5:44am |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
Could it be the body control unit. On earlier models it is the black box under the front passenger seat, maybe the connections need checking. Tom
26th May 2017 7:35am |
Phils Member Since: 01 Aug 2016 Location: North west Posts: 71 |
First step on a modern car with weird problems is to remove the battery connections overnight and charge battery.
26th May 2017 10:07am |
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 |
Couldn't get into it this morning using the remote and had to put the key in the special place again but once that was done, the car worked perfectly.
26th May 2017 11:07am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
i reckon its a battery disconnect time...Phils solution sounds right.. ... - .- -.
26th May 2017 11:09am |
I'll give it a try over the weekend. |
26th May 2017 12:38pm |
Battery disconnect procedure seems to work for lots of cars. Hope it sorts it out
26th May 2017 2:32pm |
Its ironic, with a pc or laptop or tablet we expect to turn them off to resolve a problem at least once a month. But cars we expect to run forever without a software glitch, despite them having more computing power in many many places..... |
26th May 2017 4:04pm |
