Home > Technical (L322) > 2010 Vogue broken
rich89
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
2010 Vogue broken
Hi,
My 2010 Vogue has decided to have another weird failure..
The car is practically dead. I can open up the car using the actual key get into the car and I have to put the fob down by the little light for the car to recognise it.
Once i've finally got it started, pretty much the only thing that works is the speedo and rev counter. If I drive it or leave it running, the odd thing will start working again (like the air vents or electric windows) but the stops after a few seconds.
It had a new battery fitted about 2 months ago and has been fine since.
When the car is running the battery shows 13.59 and when it's not it was showing 12.79.
Any ideas what it could be?
Post #439632 25th May 2017 9:40pm
Rob99
First thing I would suggest is to have the fault codes read as that might point you in the right direction. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #439644 26th May 2017 5:44am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Could it be the body control unit. On earlier models it is the black box under the front passenger seat, maybe the connections need checking. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #439656 26th May 2017 7:35am
Phils
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Zambezi Silver
First step on a modern car with weird problems is to remove the battery connections overnight and charge battery.
Your battery sounds good, 12.8 is fully charged, but it never hurts to charge.
After,60 secs after, both battery leads are disconnected from battery short them out together. This will fully discharge the car.
Next morning reconnect start up and you may find everything works.
Modern electronics do go dolally occasionally, this will reset most problems. It will not cure real problems. But it is amazing how many cars can be fixed by doing this.......
Post #439677 26th May 2017 10:07am
rich89
Couldn't get into it this morning using the remote and had to put the key in the special place again but once that was done, the car worked perfectly.
Scanned it and the only permanent issue is the fuel sender unit 2.
Such a pain.
Post #439682 26th May 2017 11:07am
i reckon its a battery disconnect time...Phils solution sounds right.. ... - .- -.
Post #439683 26th May 2017 11:09am
rich89
I'll give it a try over the weekend.
Post #439689 26th May 2017 12:38pm
Rob99
Battery disconnect procedure seems to work for lots of cars. Hope it sorts it out Thumbs Up
Reminds me of the classic, and over used, IT helpdesk response...........
".........have you tried unplugging it and then plugging it back in again Sir. That usually works....."
Rolling with laughter Rolling with laughter 2021 D350 Fifty Edition - Carpathian Grey
Post #439705 26th May 2017 2:32pm
Phils
Its ironic, with a pc or laptop or tablet we expect to turn them off to resolve a problem at least once a month. But cars we expect to run forever without a software glitch, despite them having more computing power in many many places.....
Post #439713 26th May 2017 4:04pm
