Home > Technical (L405) > Stalling on startup |
WillyT Member Since: 12 Aug 2016 Location: UK Posts: 90 |
Hi Stuart
18th May 2017 4:38am |
Bluestu33 Member Since: 31 Dec 2014 Location: Cambridgeshire Posts: 69 |
Apologies, as I forgot to update my profile.
18th May 2017 7:13am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1447 |
If it does it every time you start it then clearly it should be showing something up on diagnostics. Get it into the dealers, insist they find out whats wrong and fix it under warranty before giving it back to you.
18th May 2017 8:00am |
scott4197 Member Since: 07 Oct 2013 Location: Wolverhampton Posts: 58 |
Not sure if you got it sorted, but I'm wondering if the air intake throttle valve is sticking shut?
2nd Jul 2017 12:18pm |
jumpin mouse Member Since: 28 Feb 2016 Location: North West Posts: 222 |
Mine had a problem starting when warm or cold and it turned out to be the air intake valve that was sticking shut. The LR Assistance bloke took it off and gave it a good clean and the problem was totally resolved. I would describe the issue as being carbon deposits causing the valve to stick. |
3rd Jul 2017 12:34pm |
Q86ARR Member Since: 28 Jul 2014 Location: Cambridge Posts: 63 |
Might be worth pointing your retailer to LTB00815
3rd Jul 2017 7:53pm |
