Home > Technical (L405) > Stalling on startup
Bluestu33
United Kingdom 2014 Range Rover Vogue SE SDV8 Loire Blue
Stalling on startup
Evening all!
I've had my 2014 since October and I love it, but and here comes a but. Recently when starting, more often that not it stalls and the only way I can get it going, is to gently accelerate for a minute with my foot on the break. After about a minute, I can pull away without stalling, but for the first few miles it feels lumpy. After that is fine, until the next day.
I recently had it serviced and asked them to check, but, they couldn't find anything and there are no warning messages.
Any ideas?
Thanks
Stuart
Post #438730 17th May 2017 7:33pm
WillyT
United Kingdom 2017 Range Rover Vogue SE SDV8 Carpathian Grey
Hi Stuart
Your profile says 2007 TDV8. Is it a 2014 as per your post ?
If 2014 is it still in warranty ? Previous
MY17 SDV8 SE Carpathian Grey, Black Pack, Ebony / Ebony Interior
MY15 SDV8 SE Causeway Grey, Black Pack, Ebony
MY09 RRS
MY06 RRS
Current
2007 TD5 Defender - Owned since new
Post #438749 18th May 2017 4:38am
Bluestu33
Apologies, as I forgot to update my profile.
Yes, it's a 2014 4.4 and yes it's still under warranty.
Thanks
Post #438759 18th May 2017 7:13am
Rob99
If it does it every time you start it then clearly it should be showing something up on diagnostics. Get it into the dealers, insist they find out whats wrong and fix it under warranty before giving it back to you.
Oh, and make sure you get a decent loaner whilst they have yours. Thumbs Up
. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #438762 18th May 2017 8:00am
scott4197
United Kingdom 2018 Range Rover Vogue SDV8 Baltic Blue
Not sure if you got it sorted, but I'm wondering if the air intake throttle valve is sticking shut?
It happened on my old MY16 SDV8.
An AA engineer came out and noticed the valve was stuck shut by removing a rubber hose.
The valve was stuck shut by, presumably, deposits from recirculated exhaust gases.
On the forums I've seen this issue a few times in relation to the SDV8 engine.
Post #443289 2nd Jul 2017 12:18pm
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
Mine had a problem starting when warm or cold and it turned out to be the air intake valve that was sticking shut. The LR Assistance bloke took it off and gave it a good clean and the problem was totally resolved. I would describe the issue as being carbon deposits causing the valve to stick.
Post #443375 3rd Jul 2017 12:34pm
Q86ARR
2015 Range Rover Autobiography 5.0 SC V8 Havana
Might be worth pointing your retailer to LTB00815
Poor starting due to soot build up on throttle butterfly
Post #443438 3rd Jul 2017 7:53pm
