Home > Technical (L322) > Faint flickering airbag light
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
I have noticed tonight in the dark that the dashboard airbag light is ever so faintly flickering.
Anyone had this before? Is it telling me of impending doom by premature bag explosion? CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #44593 4th Jan 2011 9:24pm
dan_uk_1984
Sounds like a dodgey earth - do you leave the AC on all the time?
Post #44611 4th Jan 2011 10:30pm
Vogue Owner
Generally I don't have the AC on in this weather CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #44625 5th Jan 2011 7:48am
dan_uk_1984
Then the moisture in the air gets into the various connections/ecu's in the car and will generally give you various errors all over the place.
You have climate control for a reason - it controls the climate within the car, not just for driver comfort, but to make sure the air is dry for the various electrical components. The A/C in this weather cycles on and off in the background removing the moisture, it wont actually make you cold.
Post #44628 5th Jan 2011 9:10am
It seems many people do not realise that Climate Control is not Air Cooling!
The car is designed to have the Climate Control on Automatic at all times unless another desired program is required. As stated the fact that the A/C light is on most of the time does not mean its cooling the car as some seem to think (including my wife).
Make sure both lights are on the end of the Auto Button and leave it be.....
Post #44630 5th Jan 2011 9:19am
JIMMYM
Vogue Owner - I've got the same problem with the air bag light flickering faintly on my TD6 - had it on Autologic at the indies last time in. Not showing any faults on SRS system so have left it alone. Maybe it's bacause I 'm opening the door and actually driving it rather than having it like a hermitically sealed computer data centre with air con and HVAC fastidiously controlled. Utter pony.
Post #45053 7th Jan 2011 12:14pm
dan_uk_1984
JIMMYM wrote:
Utter pony.
If you're going to rubbish my comments - please objectively explain why?
Post #45063 7th Jan 2011 12:48pm
Patricktet
2006 Range Rover Vogue Td6 Buckingham Blue
I have the same flickering airbag light, did you find out what it was? MY 06 Vogue TD6 Buckingham Blue
Post #212047 24th Sep 2013 6:49pm
the occupancy sensor might be faulty..does the light flicker when you move about in the seat.. ... - .- -.
Post #212058 24th Sep 2013 7:24pm
Do you always use the AUTO A/C setting.... Whistle
Post #212071 24th Sep 2013 7:59pm
Patricktet
AC is always on, and the car is in a garage overnight. I have been out jumping up and down it the seats without any difference, still flickering Sad MY 06 Vogue TD6 Buckingham Blue
Post #212152 25th Sep 2013 7:34am
try doing that in the passenger seat and see if that makes a difference.. ... - .- -.
Post #212156 25th Sep 2013 7:46am
Patricktet
did that already Wink maybe the flickering only stops after switching on/off the ignition? or should it clear right away? Will try with a passenger in the other seat. MY 06 Vogue TD6 Buckingham Blue
Post #212157 25th Sep 2013 7:49am
also check the connections under the seat , one might be loose or even the pins might be corroded.. ... - .- -.
Post #212158 25th Sep 2013 7:51am
