Home > Technical (L322) > Faint flickering airbag light |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 |
I have noticed tonight in the dark that the dashboard airbag light is ever so faintly flickering.
4th Jan 2011 9:24pm |
Sounds like a dodgey earth - do you leave the AC on all the time? |
4th Jan 2011 10:30pm |
Generally I don't have the AC on in this weather CURRENT : FFRR 2012 4.4 TDV8
5th Jan 2011 7:48am |
Then the moisture in the air gets into the various connections/ecu's in the car and will generally give you various errors all over the place.
5th Jan 2011 9:10am |
It seems many people do not realise that Climate Control is not Air Cooling!
5th Jan 2011 9:19am |
If you're going to rubbish my comments - please objectively explain why? |
7th Jan 2011 12:48pm |
Patricktet Member Since: 04 Aug 2013 Location: Norway Posts: 7 |
I have the same flickering airbag light, did you find out what it was? MY 06 Vogue TD6 Buckingham Blue |
24th Sep 2013 6:49pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35374 |
the occupancy sensor might be faulty..does the light flicker when you move about in the seat.. ... - .- -.
24th Sep 2013 7:24pm |
Do you always use the AUTO A/C setting.... |
24th Sep 2013 7:59pm |
AC is always on, and the car is in a garage overnight. I have been out jumping up and down it the seats without any difference, still flickering MY 06 Vogue TD6 Buckingham Blue |
25th Sep 2013 7:34am |
try doing that in the passenger seat and see if that makes a difference.. ... - .- -.
25th Sep 2013 7:46am |
did that already maybe the flickering only stops after switching on/off the ignition? or should it clear right away? Will try with a passenger in the other seat. MY 06 Vogue TD6 Buckingham Blue |
25th Sep 2013 7:49am |
also check the connections under the seat , one might be loose or even the pins might be corroded.. ... - .- -.
25th Sep 2013 7:51am |
