Home > Maintenance & Mods (L322) > Jack which can lift the full fat wheel off the ground
Page 1 of 5 12345>
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi all,
Can anyone recommend a bottle jack or car jack which can lift high enough for the full fat to get the wheel off the ground ?
i end up using the stock jack which is a pain, and mine is showing its wear as my normal jack just dont get the wheels high enough to remove them.
any recommendations be helpful.
thanks
Karl 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #437337 7th May 2017 12:34pm
HGv driver
Wales
most people here use the MB sprinter van bottle jack plenty on ebay or search on here jack
Post #437338 7th May 2017 12:45pm
HGv driver
Wales
http://www.fullfatrr.com/forum/topic40554.html?highlight=jack
Post #437339 7th May 2017 12:48pm
b348xyx
thats what i am looking for Smile
thank you 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #437340 7th May 2017 12:50pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Where do you stash this jack when not in use, or, thinking about it, where's the standard jack. Just realised I haven't found one yet in my motor Rolling Eyes
Post #437359 7th May 2017 4:13pm
alistairh
Next to the spare wheel there's a rubber holder that holds the jack. I've managed to get mine to hold my bottle jack in situ.. as long as you mind and rotate the jack every now and again it's fine
Post #437361 7th May 2017 4:16pm
rodp
Ah, should the original be horizontal, in front of the spare wheel ? Would it have been a scissor jack. Noticed an empty "gap" but it's not very high. Thinking about it, looks scissor jack shape.
Post #437366 7th May 2017 4:36pm
Weegie
Yes original is scissor jack in straps in front of the spare wheel. (behind it looking from the back). It was/is a dangerous load of carp. John
GAP iiD BT
Post #437367 7th May 2017 4:38pm
n1cktdv8
I'm going to get a Merc bottle jack. I don't trust the scissor jack that's supplied and my 3 tonne trolley was bought purely fo the FFRR, and I leave that at home !! Is this where I put the car details and a bit about myself ?........
Post #437369 7th May 2017 4:48pm
rodp
Thanks Thumbs Up
Post #437373 7th May 2017 5:10pm
miggit
Why do 3 ton trolley jack weigh 3 tons Rolling Eyes
I've got a 2.5 ton Ally / steel hybrid jack... a lot lighter than an all steel construction jobby... But for emergancy use only then a Mercedes Sprinter bottle jack is the way to go!! Yesterday I couldn't spell Engineer... Today I are one!
Post #437502 8th May 2017 11:59am
buffalo4
2009 Range Rover Vogue SE TDV8 Bournville
In emergency I like a jack from the AA especially on the hard shoulder
Life threatening on there Big Cry
Post #437506 8th May 2017 12:12pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Merc sprinter as mentioned and an Iveco Daily jack will do the job.
Post #437859 10th May 2017 1:19pm
naks
South Africa
When I bought my D4, I simply got a decent 3t bottle jack, and got a solid, square piece of wood to use as a base plate Thumbs Up Discovery 4 Workshop Manual: http://bit.ly/22l8YHh
Defender Puma Workshop Manual: http://1drv.ms/1nNpJeM
Range Rover/Sport Workshop Manual: http://bit.ly/2iH7jgG
Post #437865 10th May 2017 1:49pm
Baltic Blue
A lot of 3-5 ton bottle jacks are only single piston lift, which is not sufficient to cope with the suspension travel, so you really need to be looking for a 3 ton + jack with a double lift even if you stand it on a block of wood you still have to allow for the amount of suspension travel. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #437889 10th May 2017 4:26pm
Page 1 of 5 12345>
