Home > Maintenance & Mods (L322) > Another Rear Arches Thread...
GGDR
Hello guys,
Was giving the Vogue a spit and polish today and with the suspension jacked up had a good look at my rear arches.
As you can see the inner lip has got early signs. Same both sides.
From the outside / with rear door open, it's as clean as a whistle.
Spent the last hour reading through this fine website, it's a well discussed topic.
EmiratesA380 posted fitting of rubbers: http://www.fullfatrr.com/forum/topic34314....ear+arches but not sure how / where that would go?
EmiratesA380 also posted http://www.fullfatrr.com/forum/topic37920....ear+arches and this seems the action I'll take. But do I need to get anything behind the wheel arch liner? i.e. other side of the rusting edge in my pics.
nicedayforit mentioned spraying engine oil around / into the arches. Perhaps this or another anti rust product pumped in behind where the metal meets the plastic inner wheel arch?
Or do I need more drastic action like removing the plastic inner arches and a more serious treatment.
Thoughts from you guys would be very much appreciated. Cheers, Greg
Post #437289 6th May 2017 7:06pm
Rubbers filled with Vaseline.
There is a LR part which fits he freelander which does the job. Can't remember the part no though. They are only a couple of quids.
Both me and MJdronfield have done threads on this too. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #437291 6th May 2017 7:35pm
GGDR
Amazing thanks NMJ!
I'm guessing this is the one:
http://www.fullfatrr.com/forum/topic9387.h...p;start=30
Crystal clear on what to do now! Cheers, Greg
Post #437294 6th May 2017 8:10pm
That's the one Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #437307 6th May 2017 9:21pm
Caddyshack
United Kingdom 2014 Range Rover Autobiography SDV8 Indus Silver
Mine did that.
Personally before fitting a strip to cover it I would rub down as much of the rust as possible and then use kurust by hammering or a bolt hammer product to halt the rust, then paint over before the Vaseline strip...if not the rust will just continue to nibble away.
Shocking that a modern car can rust so quickly, imassumed mine did it as previous owner has a boat in Marbella and my car had a tow bar, I just thought he had backed it in to salt water but maybe not.
Post #437310 7th May 2017 7:38am
pld118
This method originally recommended by nicedayforit is simple, cheap and stops corrosion. Used it on a 2007 for two years and have used it in our 2012MY for two years and not a hint of arch rust Thumbs Up
http://www.fullfatrr.com/forum/topic22530.html?highlight=comma
Post #437313 7th May 2017 8:34am
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Fitted the Freelander covers and loaded them with Waxoyl before I fitted them - no issues nearly 3 years down the line Wink
Post #437314 7th May 2017 8:37am
TJH1985
We did ours 3 years ago as they had early signs, removed rust, rust eater and then a two part epoxy mastic, followed by a submergable grease and freelander strips. We've taken the strips off today and cleaned out all the grease and there is no sign of rust.. we have even removed a little paint to check underneath and it's spot on. We used products from rust.co.uk that we use on a defender whenever we work on components.
We did remove the wheel arch liners, there is a clip that pushes onto a stud near the top that also corrodes so we got that and the inner arch while we were at it.
Rubbish design Big Cry
Post #440514 3rd Jun 2017 10:01am
GGDR
That sounds like a belt and braces job TJH1985, if it's in such good shape a few years on you've done a great job.
Are the liners hard to remove?
. Cheers, Greg
Post #440638 4th Jun 2017 4:47pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I need to do this as mine has got similar amounts of rust as in the first photos.
Must remember to do it though! Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #440668 5th Jun 2017 7:54am
TJH1985
I think they were only the forwards facing mudflap bolts, two small bolts bolts into the arch and the top metal retainer that screws off by hands (its this that corrodes). To be honest we stripped it all down to check / seal as they also corrode on the rear inside of the cills which you can only see from under the cars or can feel if you put your hand and feel the very rear of the cill closest to the rear wheels (follow the plastic cill cover down from the arch and check the cill there) , so we did that at the same time.
We must have been to see 20ish cars when we were looking 3 years ago, and they had all started to go in the same spots must just be the salt on the roads etc the one we have was the best we could find.
Ours has had a good coating of DINITROL ML in key areas Thumbs Up
Post #440670 5th Jun 2017 7:58am
