Home > Maintenance & Mods (L322) > 2006 TD6 which brake system ?
oldman
United Kingdom 2006 Range Rover Vogue Td6 Adriatic Blue
I am told the pads for my 2006 l322 could be 1 of 2 systems Lucas or Teves? How do i tell which ?
Thanks in Advance Previous : 2 x Discos, 2 x E Class Mercs, 2 X JAguar XJ's, Renault Megane, Peugeot 407 saloon, BMW X5 3.0 TD, BMW 325i Convertible, BMW 525d Estate
Current : 407 SW Exec (Everyday), FFRR 3.0 TD (Any other time)
Post #440515 3rd Jun 2017 10:44am
Front or rear? The rear are all the same across the engines iirc, only the fronts change but hances are being a 2006 it will be the later pads for the front. I've never had a problem ordering mine from LR or eBay even FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #440545 3rd Jun 2017 6:31pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Re: 2006 TD6 which brake system ?
Not sure who advised you there. The early cars had ATE brakes, the later ones, when Ford took over, were TRW.
If your car is a 2006 MY, with the revised headlights, it should have the TRW brakes. Have a look at Advanced Factors web-site, they are very good.
Post #440573 4th Jun 2017 6:54am
As GDM said you should have TRW brakes if it is a Ford era TD6 , quickest way to check is you should have ventilated rears as well. 2008 MY Supercharged
Post #440613 4th Jun 2017 12:03pm
