Home > In Car Electronics (L322) > 02-05 sound system differences...
Danwilderspin
Hi all I found somewhere a while back an explanation on what sound systems were available for our cars...
I think it was 5 speaker SE
11 speaker hse
12 speaker vogue
15 speaker hk/l7
Am I correct?
Next could anyone tell me how the 11speaker hse sound compares to the dsp 12 speaker setup? (With dsp in standard mode without effects on?)
I am potentially looking at swapping amps for my nbt setup so I can retain the stock speaker setup...
Cheers
Post #436682 2nd May 2017 6:09am
Willos
England 2002 Range Rover Vogue 4.4 V8 Java Black
If you have a vogue the speakers are 8ohm im thinking of just taking the whole lot out and replacing with up to date ice
Post #436697 2nd May 2017 9:22am
Danwilderspin
ha you look pretty local...
tbh - I was going to do the same thing but after fitting the net the sound is 10x better with the dip setup but it randomly cuts out as it needs recoding - I'm hoping that the hse amp will be similar without the effects - the vogue I have is 4ohm...
Post #436700 2nd May 2017 9:32am
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #436748 2nd May 2017 4:37pm
Danwilderspin
Thanks for that any comment on quality differences and pinouts?
Post #436755 2nd May 2017 4:53pm
mjdronfield
Pinouts and those pics are in RAVE. There is a download link in the Wiki....
I had Baris do a stage 2 amp upgrade on my TD6 and it blew the standard fit systems out the water. All my speakers were still stock....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #436760 2nd May 2017 5:04pm
Danwilderspin
I maybe wrong isn't the stage 2 on the bm54 unit not the dsp? If so you will be seeing differences like I am on the nbt...
That's for that pinout will look on rave it was the other amp pinout I was after non dsp Smile thanks!
Post #436762 2nd May 2017 5:15pm
mjdronfield
Yea, the upgrade was on the BM54.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #436765 2nd May 2017 5:40pm
Danwilderspin
Cool thanks - if anyone could comment on the sound that would be grest
Post #436786 2nd May 2017 6:30pm
