![]() | Home > Technical (L322) > Inadvertently selected reverse going downhill - awful noise! |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1453 ![]() ![]() |
As it says.........was travelling down a short hill and to avoid engine braking I usually just drop it into neutral until i get to the bottom but today went too far and selected reverse |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
My dad used to slip his auto into neutral for a coast down a hill. It eventually |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35489 ![]() ![]() |
just thinking about that scenario the other week Rob and wondered if it was possible to put it into reverse whilst going forward and you have proved that it is ..
It's only a 200yd section at my kids school. I only do it there as when it gets to the bottom it seems to take a second or two for it to pick up if i leave it in drive. I'm not convinced that letting it engine brake with my foot off the gas is the best thing to do downhill either.
My guess is that, as the selector is only a switch and not a physical link, the gearbox control system wont select reverse if the forward speed is too high. I'm sure some clever auotbox person (like RRPhil) would be able to confirm that. Went on a 100 mile trip this afternoon and everything seemed absolutely normal. ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
There def must be a logic controller. Sometimes I kill the engine forgetting it's in D and some brain pops her into P automagically. So hoping you're alright. Cheers, Greg
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 814 ![]() ![]() |
Putting the engine into neutral to coast seems like a bad idea to me.
syl Member Since: 24 Jan 2017 Location: Somerset Posts: 30 ![]() |
It's pretty similar to the jaguar setup I'd have thought. Here's an interesting thread:
i dont think i would ever risk putting mine into reverse at 60mph |
Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115 ![]() ![]() ![]() |
Having just come from an Audi with a similar knob for the computer I'm worried I'm going to select reverse while zooming out the sat Nav, have nearly done it a couple of times. |
It's not coasting, it's a short steep hill. Yes, it probably isn't allowed in the driving test, but as for not in proper control, you control a vehicle down a steep incline with the steering and brakes not the accelerator. 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
It is not a good idea to coast in neutral with an auto box.
As above, use HDC if you must but if its moving stick it in Drive or Reverse depending on the direction of travel. We know about rebuilding the 6&5 Speed boxes on here but the 8speed ones..... that could be very very costly! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I think you've been VERY lucky. I "assumed" that the box selector wouldn't allow this change of gear (and potential direction) above a certain speed....if it can |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
I would hope to think you are ok.
