Home > Technical (L322) > Inadvertently selected reverse going downhill - awful noise!
Rob99
As it says.........was travelling down a short hill and to avoid engine braking I usually just drop it into neutral until i get to the bottom but today went too far and selected reverse Rolling Eyes
Awful juddering and loud noise and unhelpful message on dash display saying "Recommend using HDC". Stuck it back in drive and its been fine since.
So, any potential damage do you think or is the fattie sensible enough not to select reverse when its moving forward (albeit at 10mph) and the juddering etc was just to tell me to stop being such an a Censored e and select drive Shocked 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #436364 29th Apr 2017 4:06pm
Fingers crossed.
If it seems fine it probably is.
Put it down to experience and move on Whistle There is nothing that can't be fixed with a hammer😜😜
Post #436365 29th Apr 2017 4:13pm
GGDR
My dad used to slip his auto into neutral for a coast down a hill. It eventually Censored the box. That was in the 70's. Maybe it's ok these days?
. Cheers, Greg
Post #436374 29th Apr 2017 5:47pm
just thinking about that scenario the other week Rob and wondered if it was possible to put it into reverse whilst going forward and you have proved that it is ..
hope all will be ok Rob.. ... - .- -.
Post #436395 29th Apr 2017 7:35pm
Rob99
gonna_go_double_r wrote:
My dad used to slip his auto into neutral for a coast down a hill. It eventually Censored the box. That was in the 70's. Maybe it's ok these days?.
It's only a 200yd section at my kids school. I only do it there as when it gets to the bottom it seems to take a second or two for it to pick up if i leave it in drive. I'm not convinced that letting it engine brake with my foot off the gas is the best thing to do downhill either.
stan wrote:
just thinking about that scenario the other week Rob and wondered if it was possible to put it into reverse whilst going forward and you have proved that it is ...
My guess is that, as the selector is only a switch and not a physical link, the gearbox control system wont select reverse if the forward speed is too high. I'm sure some clever auotbox person (like RRPhil) would be able to confirm that.
Went on a 100 mile trip this afternoon and everything seemed absolutely normal. Whistle 2017 4.4 SDV8 Autobiography
Post #436402 29th Apr 2017 8:21pm
GGDR
There def must be a logic controller. Sometimes I kill the engine forgetting it's in D and some brain pops her into P automagically. So hoping you're alright. Cheers, Greg
Post #436405 29th Apr 2017 8:35pm
Rambles
Putting the engine into neutral to coast seems like a bad idea to me.
If you did this on a driving test, I think it would be a fail? Not in proper control of the vehicle....
Post #436568 1st May 2017 7:17am
syl
It's pretty similar to the jaguar setup I'd have thought. Here's an interesting thread:
http://www.jaginfo.org/showthread.php?55377-Reverse-at-70mph
Post #436573 1st May 2017 8:08am
i dont think i would ever risk putting mine into reverse at 60mph Shocked ... - .- -.
Post #436574 1st May 2017 8:12am
Freddie The Fish
United Kingdom 2011 Range Rover SE 4.4 V8 Fuji White
Having just come from an Audi with a similar knob for the computer I'm worried I'm going to select reverse while zooming out the sat Nav, have nearly done it a couple of times.
Post #436582 1st May 2017 9:15am
Rob99
It's not coasting, it's a short steep hill. Yes, it probably isn't allowed in the driving test, but as for not in proper control, you control a vehicle down a steep incline with the steering and brakes not the accelerator. 2017 4.4 SDV8 Autobiography
Post #436614 1st May 2017 2:02pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
It is not a good idea to coast in neutral with an auto box.
Oil pressure in the box is maintained by the drive from the engine, not from the driven wheels over-running. This eventually causes issues with excessive wear in the box as it can be turning inside at road speeds without the necessary attendant oil pressure.
Usually OK for a manual box as they generally don't have an oil pump fitted, but rely on the gears being partially immersed in the oil
Post #436707 2nd May 2017 9:51am
As above, use HDC if you must but if its moving stick it in Drive or Reverse depending on the direction of travel. We know about rebuilding the 6&5 Speed boxes on here but the 8speed ones..... that could be very very costly! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #436881 3rd May 2017 9:48am
n1cktdv8
I think you've been VERY lucky. I "assumed" that the box selector wouldn't allow this change of gear (and potential direction) above a certain speed....if it can Shocked Shocked Shocked
Hopefully no damage....if it's working ok, it's likely fine. Is this where I put the car details and a bit about myself ?........
Post #436882 3rd May 2017 9:55am
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
I would hope to think you are ok.
We lost brakes on our Rhino Charge last year (more on that to follow) and had to drop the car into reverse to stop a couple of times from a very slow idle - ended up Censored the box and had to get a new one Sad
Would think that the more modern cars would be able to use their electrickery to prevent this happening though!
C African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #436884 3rd May 2017 10:16am
