![]() | Home > Technical (L322) > L322 halogen type level sensor |
Louismacrides Member Since: 18 Mar 2017 Location: Weston Posts: 69 ![]() ![]() ![]() |
Hello do you repair these ,seems a waste not to .
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
if you have or can get some kevlar thread , squeeze the part back together, rope the tred around and then saturate kevlar with tin superglue or epoxy. |
Strips of duct tape wrapped around worked for me for many years, until the rod came out of the rubber connector and the alloy ring inside completely corroded away. Gave up and bought a new one. (not like me! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
If it's rubber then vulcanising cement might work. Like the stuff you get for puncture repair kits. Go and stand i front of the adeshive rack in Halfords. There are a dozen or so different glues for different things. There is nothing that can't be fixed with a hammer😜😜
