Home > Technical (L322) > L322 halogen type level sensor
Louismacrides
United Kingdom 2004 Range Rover Vogue SE 4.4 V8 Epsom Green
Hello do you repair these ,seems a waste not to .
Post #436343 29th Apr 2017 1:32pm
ether by plastic welding the piece back together, or super glue, or depending on the type of plastic solvent weld may work.
many options but not knowing what plastic it is makes it more difficult. First and leat destructive I would suggest a 2 part glue either a superglue and activator or some sort of epoxy like araldite. There is nothing that can't be fixed with a hammer😜😜
Post #436352 29th Apr 2017 3:29pm
nino_nino
if you have or can get some kevlar thread , squeeze the part back together, rope the tred around and then saturate kevlar with tin superglue or epoxy.
Post #436389 29th Apr 2017 7:54pm
Strips of duct tape wrapped around worked for me for many years, until the rod came out of the rubber connector and the alloy ring inside completely corroded away. Gave up and bought a new one. (not like me! Smile ) .
Post #436420 29th Apr 2017 11:01pm
If it's rubber then vulcanising cement might work. Like the stuff you get for puncture repair kits. Go and stand i front of the adeshive rack in Halfords. There are a dozen or so different glues for different things. There is nothing that can't be fixed with a hammer😜😜
Post #436438 30th Apr 2017 8:33am
Louismacrides
My fun
Post #436897 3rd May 2017 3:08pm
