Home > In Car Electronics (L322) > Looks snazzy but will it fit?
Page 2 of 3 <123>
GGDR
Err - I thought that... But fitted a button-less one in my Toyota. But I found you REALLY need a volume dial. I never realised. So I changed it to a different unit. Also , that screen would foul on the hooded dash no? Cheers, Greg
Post #436152 27th Apr 2017 9:32pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Luckily it will work with the steering wheel volume controls etc.
The touching of the dash top is the sticking point at the moment..... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #436158 27th Apr 2017 9:47pm
GGDR
BTW I saw what looked like the same one but quite a bit cheaper on eBay Cheers, Greg
Post #436161 27th Apr 2017 9:56pm
UK Marine
Do you have the link? ______________________________
Simon
Post #436171 28th Apr 2017 12:09am
GGDR
Searched X5 9"
http://www.ebay.co.uk/itm/Android-6-0-DAB-...Sw7GRZAcGV
or
http://www.ebay.co.uk/itm/9-Car-Stereo-GPS...2299098500
I haven't checked the spec - pls check over it make sure it's got the same as the other one. Cheers, Greg
Post #436175 28th Apr 2017 12:32am
GGDR
Plenty on amazon too... Around the £300 mark Cheers, Greg
Post #436177 28th Apr 2017 1:15am
UK Marine
Hi, thanks for the links. I've just had a reply from Erisin asking if I would take some photos of the plugs going into the head unit and BM54, so they can determine if it's compatible.
I think I know the answer as it's all based on an X5 anyway but I'll send the pics off as it covers me if it's not compatible.
Regards ______________________________
Simon
Post #436208 28th Apr 2017 10:36am
p38arover
Australia
The DAB radio stations in the eBay ad pics are in Sydney. Smile Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #436225 28th Apr 2017 12:54pm
UK Marine
I managed to get some extra measurements from Erisin for this unit specifically the screen size from bottom to top.
Anyway it's 185mm which in old money is about 7 inches which would mean it sticking above the dash top panel by about 2 inches. Add to that the fact it doesn't extend far enough out to miss the dash top means to fit it I would have to cut and modify the dash top panel.
I do like this head unit but not enough to modify my dash top, so although the electronics look like they would work, the physical immensity of this thing wouldn't, so back to the drawing board Thumbs Up
Simon
Post #436258 28th Apr 2017 4:21pm
Danwilderspin
do the nbt retrofit - I'll have a full kit for sale (with the emulator soon) keep the oem functionality and have speed limit info and backup cam lines Very Happy
Post #436711 2nd May 2017 11:48am
UK Marine
Sounds like a solid plan B.
I was following your link but it seemed a bit too confusing so I'll have another look now.
Cheers ______________________________
Simon
Post #436732 2nd May 2017 3:32pm
Danwilderspin
Ok no worries - i need to update it tbh I now have the carsystems adapter which works better and gives you speed limit info and front and rear camera support.
The only stumbling block I have is the dsp system as no one seems to be able to recode them on a ff they need to be dropped into and e39 or e53 but no one wants to help Sad I have a plan b which hopefully will pan out in the next week or so which is to get the amp from the hse and replace it hopefully leaving the speakers in tact. Worst case I would need 4 sets of components but trying to work out the path of least pain!
Post #436738 2nd May 2017 3:58pm
phat_dogg
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi Guys,
I took a gamble and bought this head unit and it works perfectly. The screen is quite large and fills in that section very well. Like you guys have mentioned the only issue is that it is too tall. However, it is only less than 1cm too tall (probably 5-8mm), so modifications to the dash would be very minimal. Just trying to find an auto trimmer to cut away.
Sorry no pics at the moment as I have taken it out until I have the dash fixed.
Cheers
Post #437795 10th May 2017 12:19am
GGDR
Great well done. Have a smaller android in our Toyota but running the same OS and it's a really great system, excellent iGO satnav, expandable (dash cam, tv, dab) so if you're willing to cut your dash top then it'll be a great upgrade. You may be able to cut or mod those curved sides to fit in better with the rest of your dash.
What year is your RR? Cheers, Greg
Post #437797 10th May 2017 12:28am
phat_dogg
Thanks mate, mine's a 2004.
Post #437799 10th May 2017 12:39am
Page 2 of 3 <123>
