![]() | Home > Maintenance & Mods (L322) > Wobbly wagon??? |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Tyre pressure?
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
One of the hub nuts working loose.. ______________________________
Rockyd31 Member Since: 17 Dec 2016 Location: Chesterfield Posts: 36 ![]() ![]() ![]() |
Thanks for the input guys.
Absolutely, jack up all the corners one after the other and check for free play.
Foulolron Member Since: 05 Aug 2015 Location: East Yorkshire Posts: 29 ![]() ![]() ![]() |
Have you checked the rear bushes - I went through two sets (genuine RR parts) in four years of ownership last time I had them replaced ended up having a new hub carrier fitted - as they got worse it started to feel "loose" at the back end |
Looks like a few things to try this weekend. Thanks all, I'll report back if I find the cause. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3811 ![]() ![]() ![]() |
You could take it for an MOT and ask them to report any bush wear .
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35606 ![]() ![]() |
i'd suggest a warped tyre or buckled wheel could be causing that.. ... - .- -.
I would try replacing each wheel in turn with the spare to see if the problem goes away with a particular wheel change. |
Madyaker Member Since: 13 Apr 2015 Location: Wigan Posts: 39 ![]() ![]() ![]() |
+1 on the buckled wheel. sounds like the exact symptoms I had. |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Putting it is neutral will not eliminate the drive train - it all still spins around. Just driven by the road wheels rather than the engine |
Finally got this isolated to the rear left corner and has been confirmed today as a warped tyre making Stan the winner. Thanks for all the input guys ![]() Pirelli scorpions £194 each corner ![]() |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Interesting. I had exactly the same issue last week. Steering was fine and not juddering, but the car felt a bit vague and the rear of the car wobbled side to side under 35 mph.
