Home > Technical (L322) > Armrest removal- easy peasy!
recoverytim
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Hi guys,
Did a bit of research on here as I have a badly worn passenger armrest. Got a new-old-stock armrest from eBay which arrives tomorrow so sussed it out when I got back from work a minute ago.
To remove the armrest is NOT a seat out job... There are 2 torx screw which can be accessed at the base of the front seats, from the back seats, by moving the magazine holder fabric to towards the middle of the seat. Whip these out and lift the rigid plastic back panel up and then towards you. The grub screw (torx) is seen from the back seats holding the armrest to the boss on the seat. If you power the seat forward on the motor to as close to the dash as possible there is just enough room to slide the armrest off!
I'm sure many of you know this, but having read many posts over the weekend saying seats need to be removed and seat bases have to come out, I hope this can help someone as I have had masses of invaluable help from the forum in the past!
All the best, Tim
Post #435320 18th Apr 2017 6:49pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Dismantled mine yesterday, while I remove the badly applied "piano black paint" from all the wood, inc the rear, also noticed the numpty lost some screws and one of the plastic sleeve bearing Rolling Eyes
Soon be back together again in cherry Wink Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #435339 18th Apr 2017 9:21pm
