Home > Technical (L322) > Engine warning on dash
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
The other day I had a very brief message accompanied by a bong of death sound,because it was only on for about a second I can't quite remember the exact message,it went something like ...engine ***** fault ....Is there a list perhaps of messages you may see on the dash or are there lots of different messages that can be displayed? It's a 2009 3.6 by the way and has been very reliable in my 18 months ownership. Or am I being paranoid about the brief message lol. 2009 Vogue SE Zermatt silver
Post #433324 31st Mar 2017 11:38am
mine used to do that........
then a few months later the turbo hose split. Cheap and easy to do there is a how to temp repair i wrote in the wiki, take the passenger side one off, takes 5 mins, and check it under the webbing to see if its started to split. There is nothing that can't be fixed with a hammer😜😜
Post #433349 31st Mar 2017 4:48pm
Stevie_b
Scotland 2002 Range Rover Vogue Td6 Zermatt Silver
Most likely.Engine system fault, you need the codes read to identify the possible cause...
Hopefully something simple. Although...
Post #433350 31st Mar 2017 5:07pm
mrtidy
I'm hoping it's a false alarm has it only came on for a second or two,I've already changed the top turbo hoses a few months ago. Fingers crossed Bow down 2009 Vogue SE Zermatt silver
Post #433634 2nd Apr 2017 10:55pm
kbald
Did the message flash up when you startd the car or whilst driving? If when starting could be the turbo actuator arms sticking and not going hrough the full range of motion. Theres a few threads on how to oil hem to stop this.
Post #433638 3rd Apr 2017 5:53am
mrtidy
No it didn't happen from start up,i had driven about 10 miles down the motorway at about 60 mph then came off on to normal roads and stopped at traffic lights,the lights changed and I started to go when a bus crossed across the front of me through a red light and I had to slam the brakes on sharply,thats when the warning popped up for about 2 seconds then went off.everything seems fine and I,m obviously hoping its a one off. 2009 Vogue SE Zermatt silver
Post #433658 3rd Apr 2017 11:32am
kbald
Normally the big faults show under load i.e turbos and egrs so the fact it was when breaking seems to be a good sign!
Post #433719 3rd Apr 2017 5:24pm
cass
Have you checked the engine oil level?
Post #433758 3rd Apr 2017 8:31pm
mrtidy
Oil level ok and nothing seems amiss and it's been well looked after because I know the guy who had it before me was a work colleague and it has been driven mainly motorway approx 30 miles each day to work and it's now done 88000 miles so I assume motorway mileage is better for the car. I'll see how things progress Very Happy 2009 Vogue SE Zermatt silver
Post #433770 3rd Apr 2017 10:14pm
