Home > In Car Electronics (L322) > New D4 BT module problem?
Eirik34
Norway
Hi, I ordered a new BT module from Wiggs last summer (ref http://www.disco3.co.uk/forum/topic53544.html) - installed it July in our 2007 L322 - and as everyone else I immediate experienced the improved sound with the new D4 type BT module. And the improved display (signal strength & service provider) on the l322 nav unit screen - great!
However, I also experienced that my smartphone at that time; a Samsung Android; did have a problem with the pairing, resulting that I had to manually pair the Samsung phone with the BT module using 2121 40-50% of the time I drove the car.
I had a dialogue with Wiggs about this, but since I was to get a new iPhone 7+ last fall, we concluded that the problems most likely was related to the Samsung android phone.
In December I got my new iPhone 7+, but unfortunately the pairing problems have continued. It works now and then, I'm guessing 50% of the times the phone will automatically pair with the new BT module in the car, and the other times I have to manually pick "Land Rover" in the BT menu on my phone, and then enter 2121 once again.
Both with my Samsung and the iPhone 7+ I of course have tried multiple times to delete "Land Rover" from the BT connections, and then do new reconnections. I have disconnected the car battery, trying to "reset" the BT that way, but still the problem persist. I've also discussed with Wiggs if there are any SW updated on the BT module to fix this, but there aren't any such updates to this module.
I'm using the iPhone 7+ with other BT devices as well (Mini Cooper S Cab, loudspeakers, headphones) - all these works without having to do a reconnect/re-pairing.
Anyone else experiencing this with the new "Wiggs" BT module? Is it "normal" that the BT pairing is lost 50% of the time with the new type BT module?
Post #433172 30th Mar 2017 6:34am
chugga90
I have similar with my 2007 RR.
Did the exchange unit with Wiggs, now sometimes it connects others it just says no phone connected.
Added annoyance is when the phone rings when not paired and I am too close to the car it pairs then and you cannot hear a thing.
This is with an iPhone.
Just accepted its a Land Rover thing!
Post #433184 30th Mar 2017 9:14am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Is the D4 one just plug and play like the L322 one was/is?
L322 ones no longer being made and no longer available according to my local dealer.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #433307 31st Mar 2017 7:48am
Eirik34
Norway
Yes Zarnd, it is quite straight forward swap, the how-to is explained here: http://www.bluetoothexchange.co.uk
Post #433340 31st Mar 2017 3:30pm
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
I have a MY06 with the original Nokia Bluetooth Module, i have the same problems with the old module.
So i guess its a Land Rover Thing Wink
Post #433371 31st Mar 2017 6:54pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
I also have a 2006 and it never pairs automatically, have to pair it and enter the code each time, I'm hoping it can be flashed with an IID tool.
Post #433378 31st Mar 2017 7:48pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
I flashed the bluetooth ecu with the iid tool on my td6, it works great now. Thumbs Up
Post #433394 31st Mar 2017 9:12pm
hamlet
Good to know, thanks... Thumbs Up
Post #433403 31st Mar 2017 10:42pm
jonnyboy54321
Could someone explain to an idiot such as myself the art of flashing the module? I have an IID BT, my fatty's bluetooth sometimes pairs sometimes doesnt with this blasted Sony phone that I hate..
Thx 2007 Vogue TDV8 with 255/55/20's fitted
Post #433455 1st Apr 2017 1:46pm
Weegie
Hi John,
https://www.gap-diagnostic.com/support/documents/IIDTool/ user manual 4.11.4 Wink
If all else fails RTFM. Whistle Rolling with laughter Rolling with laughter John
GAP iiD BT
Post #433466 1st Apr 2017 3:11pm
gregdav
If a technophobe like me can do it, I can't see you having any problems. Laughing
be sure battery is charged , or on ctek charger. Takes about an hour.
I don't have to pair my phone at all, it recognises the the phone every time, well worth it. Thumbs Up
Post #433484 1st Apr 2017 4:48pm
Eirik34
Norway
This weekend I tried to upgrade the BT ECU according to the description in the IID manual chapter 4.11.4, using my IID BT tool, but I get error messages half way during the upgrade: "Operation Failed E 4". I even tried using a PC connected to the IID tool (as described in the IID manual). And - used a CTEK connected while upgrading, so the voltage should not be a problem. Strange!
Post #433651 3rd Apr 2017 9:02am
