Home > Maintenance & Mods (L322) > Non starting issue, Starter motor replacement?
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Thinking that my starter has packed up. First I thought it was the battery going down as I've been in need of a replacement for some time. It was making a sound like a cat coughing up a fur ball when starting on Thursday and Friday morning going to work, I got to work and ordered a new battery. Drove it home and after turning it off by the house it then failed to restart the second time, first time it really struggled making that noise. I even tried another battery with jump leads, nothing. Fitted a new battery today and nothing but a click. The dash lights up and everything comes on as normal but nothing but one click from under the bonnet. The penny then dropped, I think my starter motor has packed up.
Also I was getting "trans fail safe" for a while and an error code for the inhibitor switch. Thing is though, it was making that horrendous noise on starting for approx two days. I'm wondering if it's a combination of both things gone at the same time. Inhibitor switch is also going to get replaced.
Where is the starter located and what sort of job is it to do. Car isn't on the drive, it's at the side of the house. I can't start it either to raise up the suspension.
Also best place to get one, recon or new? 2004 RR 4.4 V8 Autobiography
Post #432888 27th Mar 2017 6:57pm
PaulM
I'm going to change the XYZ inhibitor switch first as that's just arrived back after refurbishment. 2004 RR 4.4 V8 Autobiography
Post #433458 1st Apr 2017 3:34pm
PaulM
Right changed the XYZ switch and still didn't start. Got under it with an extension bar and hit the starter while somebody turned it over and it fired up. Sounded very rough the starter did first time but now it turns over every time which I find odd. I'm not convinced though that's the end of the issue even though the starter sounds ok and starts. 2004 RR 4.4 V8 Autobiography
Post #433654 3rd Apr 2017 11:42am
sorry i cant help but i'm sure there'll be a more knowledgable member along soon.. ... - .- -.
Post #433655 3rd Apr 2017 11:56am
StewD
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Paul there's tons of online chat about starter issues. Sounds like the solenoid is failing or in need of a bit of attention.
The mobile site view of FFRR doesn't list your car spec...
There'll be more assistance I'm sure..
Here's a few links to be getting on with
http://www.rangerovers.net/forum#/topics/38545?page=1
http://www.rangerovers.net/forum#/topics/44760?page=1
http://www.fullfatrr.com/forum/topic1262.html?view=next
http://www.disco3.co.uk/gallery/albums/use...cement.pdf Current: Supercharged 06 FFRR in Java Black
Previous: BMW 740D M Sport
Previous Previous: BMW 730D Sport
Post #433771 4th Apr 2017 12:01am
PaulM
Thanks for the links, it's a 03 4.4 petrol M62 engine. 2004 RR 4.4 V8 Autobiography
Post #433988 6th Apr 2017 6:36am
StewD
Did you ever get anywhere with your starting issue ?? Current: Supercharged 06 FFRR in Java Black
Post #478265 13th May 2018 2:28pm
