![]() | Home > Technical (L405) > Front Cool Box |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
It is a fridge, mine will definitely have a cold drink after 5 bours |
AMTony Member Since: 01 Mar 2017 Location: North West Posts: 81 ![]() |
Yes, green light is on but only works when ignition is on.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7991 ![]() ![]() ![]() |
Mine only works with the ignition on - but after a decent drive the drinks are cool |
In the handbook it says not to leave switched on as it can drain the battery.
Lutonboy Member Since: 26 Dec 2016 Location: Bedfordshire Posts: 35 ![]() ![]() ![]() |
It's not a fridge in the true sense, it's a thermally insulated box with an attached heat sink and fan which is activated by the switch in the centre console. It's really a cool box, if the item goes in cold then it will maintain that coldness over a journey but it will not make things cold. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35592 ![]() ![]() |
does having the AC on/off affect the box? ... - .- -.
Always keep a/c on.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Stick a cold brew in it. After the next 5 hours it'll be ready to drink |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 ![]() ![]() |
It uses a Peltier cooling device, so should cool the compartment down. If it is heating up, it is not out of the question that the power supply has been reversed! |
I am 90% sure mine has cooled down drinks and not just kept them cool |
Sounds like it's wired the wrong way. It uses a Peltier unit, much the same as heated/cooled seats do. Connect it up and it should get cold, but if the +ve and -ve are the wrong way it will heat up instead. |
