![]() | Home > In Car Electronics (L322) > Upgrade to Logic 7 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7879 ![]() ![]() ![]() |
The BMW stuff is not interchangeable with the MOST system, but as you have a car on the changeover with perhaps the mix of kit I'm not sure. I know the logic 7 speakers should be an upgrade by themselves from what I hear from others.....
You may have Logic 7 but just older door cards without the little badge , do you have the setting for Logic 7 in your audio settings screen? 2008 MY Supercharged
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
If you have the touchscreen sat nav system then you will have logic 7, the speaker covers will just say Harmon Kardon on them. Press the lower left toggle buttons to get the audio settings and it will have the logic 7 option, select it and the difference will be noticeable.
khyber Member Since: 21 Mar 2017 Location: new york Posts: 30 ![]() ![]() ![]() |
I have the 2004 non touch screen HK Logic 7 system. It sounds great. Don't think all Logic 7 systems use MOST. |
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
My bad - just re-read my original post.
If your sat nav is non-touchscreen then you wont be able to use anything from an 05 touchscreen system, as the old BMW system is not MOST. I don't think upgrading the speakers will give any benefit, as the Logic 7 setup is more of an electronic amplifier system, the HK Speakers are probably the best for the FF's as is.
