Home > In Car Electronics (L322) > Upgrade to Logic 7
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Upgrade to Logic 7
Hi all,
Quick question for those in the know. My touchscreen Vogue has the DSP but not Logic 7. I can lay my hands on a Logic 7 system from a 2005 touchscreen model. Will the system work or are they different between the BMW and MOST setups? Failing that, are the Logic 7 speakers a good upgrade?
Cheers, Matt 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #431892 21st Mar 2017 12:53pm
mjdronfield
The BMW stuff is not interchangeable with the MOST system, but as you have a car on the changeover with perhaps the mix of kit I'm not sure. I know the logic 7 speakers should be an upgrade by themselves from what I hear from others.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #431970 21st Mar 2017 7:59pm
You may have Logic 7 but just older door cards without the little badge , do you have the setting for Logic 7 in your audio settings screen? 2008 MY Supercharged
Post #432028 22nd Mar 2017 1:17am
Discotigger
If you have the touchscreen sat nav system then you will have logic 7, the speaker covers will just say Harmon Kardon on them. Press the lower left toggle buttons to get the audio settings and it will have the logic 7 option, select it and the difference will be noticeable.
Post #432124 22nd Mar 2017 7:33pm
khyber
United States 2004 Range Rover HSE 4.4 V8 Zambezi Silver
I have the 2004 non touch screen HK Logic 7 system. It sounds great. Don't think all Logic 7 systems use MOST.
Post #432265 23rd Mar 2017 3:21pm
SidewaysMatt
My bad - just re-read my original post.
Missed the non- from in front of touchscreen Embarassed
So basically the question is will a Logic 7 system from 05 touchscreen FF work with a 04 non-touchscreen FF. I'm guessing not...
However from what I've read, the speakers on their own may be a worthwhile upgrade. 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #432268 23rd Mar 2017 3:30pm
Discotigger
If your sat nav is non-touchscreen then you wont be able to use anything from an 05 touchscreen system, as the old BMW system is not MOST. I don't think upgrading the speakers will give any benefit, as the Logic 7 setup is more of an electronic amplifier system, the HK Speakers are probably the best for the FF's as is.
You may be better off trying to source an upgraded DSP to get the best out of the speakers.
Post #432272 23rd Mar 2017 3:59pm
