Home > Maintenance & Mods (L322) > height sensor removal and replacement?
D34NO
United Kingdom 2003 Range Rover HSE Td6 Monte Carlo Blue
Hi all had a good look around and there is lots of threads on height sensors and faults about them, i'm just wondering how easy it is to remove and replace with a new one? i don't exactly have a lot of space to work in so i'm kind of hoping its just a case of jacking up the car and getting under neath with a few tools then ten minutes later its done..........or is this wishful thinking? lol
Post #430806 11th Mar 2017 3:23pm
D34NO
As i finished typing this i saw RAVE so i installed and looked through......shouldn't take long at all really?!!
Post #430807 11th Mar 2017 3:30pm
Sharpy1980
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Provided the bolts don't snap I reckon 10 mins is fair, hardest part is jacking up and taking the wheel off Thumbs Up
Good luck with it
Post #430819 11th Mar 2017 5:27pm
You can do the front ones without removing the wheels, but need the wheel off for the rear ones.
From memory, having just removed a rear one, 5/32 hex or Torx 25 for the two little bolts holding the sensor in place, 13mm both sides where the arm connects. For the rear, I find it best to release the sensor first, then turn it around so you can get at the clip to remove the electrical connector. .
Post #430877 11th Mar 2017 11:55pm
