Home > Technical (L322) > 4.4 TDV8 Bonnet open |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
switch or latch....mine sometimes needs a further 'click' to make sure its fully closed... ... - .- -.
6th Mar 2017 6:06pm |
Dogfishdave Member Since: 09 Feb 2016 Location: Bristol Posts: 76 |
Thanks Stan, I will check it out.
6th Mar 2017 6:11pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
The plastic bracket holding the switch may be broken allowing the switch to drop and causing the bottom on the switch to not be fully depressed. ______________________________
6th Mar 2017 9:16pm |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 |
If I let my bonnet drop from about eight inches it latches fine. If I push it shut, the dash warning comes up once I start moving. Guess which method of closing it I use. |
6th Mar 2017 9:26pm |
Thanks lads, I will check it out at the weekend, just finished work |
7th Mar 2017 7:55pm |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 |
I had the same issue on my 4.4 tdv8. I gave the switch a good spray with wd40 and no more issues. |
8th Mar 2017 8:31am |
