![]() | Home > Technical (L322) > 4.4 TDV8 Bonnet open |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
switch or latch....mine sometimes needs a further 'click' to make sure its fully closed... ... - .- -.
Dogfishdave Member Since: 09 Feb 2016 Location: Bristol Posts: 76 ![]() ![]() ![]() |
Thanks Stan, I will check it out.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
The plastic bracket holding the switch may be broken allowing the switch to drop and causing the bottom on the switch to not be fully depressed. ______________________________
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 ![]() ![]() ![]() |
If I let my bonnet drop from about eight inches it latches fine. If I push it shut, the dash warning comes up once I start moving. Guess which method of closing it I use. |
Thanks lads, I will check it out at the weekend, just finished work |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
I had the same issue on my 4.4 tdv8. I gave the switch a good spray with wd40 and no more issues. |
