![]() | Home > eBay & Bargain Spots > Full L322 Interior LED Upgrade Kit! |
biggles3124 Member Since: 03 Mar 2012 Location: Andover, Hants Posts: 103 ![]() ![]() ![]() |
I bought a set of LEDs for my 08 Vogue TDV8 3.6 from Lightec Autostyle Ltd on eBay for £29.99 posted. All OK except mirror puddle lights where I had to solder the provided resistor across the 2 wires to lamp holder. Full instructions for removing the lamps is contained in your handbook and a plastic trim tool or normal small electrical screwdriver is advised.
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
I bought this kit for my 2012 AB:
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
Just to continue this thread - I've just tried to fit the kit that GAC23 linked to in the previous post. Started with the roof console (reading light / main overhead above driver); getting the unit off was much less obvious than I thought (there's two 8mm hex screws in the sunglasses bit, then you have to lever off the whole unit, bit scary).
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
you dont have to remove the whole console, the light cluster can be levered off from the rear...you can then dismantle the cluster by undoing two small screws... ... - .- -.
Yes, it pops out.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1481 ![]() ![]() |
Bumping this thread.
I had these:
