Home > Technical (L322) > Another not starting issue, key turns, engine doesn't. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
You found the screws then?
27th Feb 2017 4:46pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Is it possible to put a jump start cable from the starter to the battery just to prove that the solenoid/starter is functioning? Previously..
27th Feb 2017 5:15pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
Suspect starter solenoid not activating, hence no large current draw, you could check for a signal on ignition at the solenoid or just give it a whack, and see if it frees up! There is nothing that can't be fixed with a hammer😜😜
27th Feb 2017 5:29pm |
desertdude Member Since: 10 Sep 2016 Location: Dubai Posts: 60 |
@weegie Yeah mate found the screws, would have been impossible to find them on my own the way they are hidden inside, so a big thanks for that, and I do have the key wont turn issue from before but I've bypassed it with a on off switch in fuse 18, so key makes a full turn and would start the car normally. And yeah I'm starting to suspect I might have to get a new one, money is super tight to mention, being out of work and all and the part is on a 15 day waiting list. So was hoping a spit and polish would do the trick.
27th Feb 2017 6:29pm |
Ok so update on the situation, well the starter was duff, had to tow it to a buddys shop where he has a dugout where we can get under the car, a few whack and the car started up, turned on and off a few times but then dead again. Undoing the starter motor wasn't a very difficult job at all, didn't need to open the manifold or anything, but now the dam thing is all loose and wont come out from anywhere, there doesn't seem to be enough space from any side to wiggle it out! Will take out the wheel tomorrow and try from there. |
7th Mar 2017 7:10pm |
OK follow up on the thread.
8th Mar 2017 11:57pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Could it be the immobiliser? |
9th Mar 2017 7:44am |
StewD Member Since: 22 Apr 2016 Location: Glasgow Posts: 129 |
Any update desertdude ? Current: Supercharged 06 FFRR in Java Black
28th Mar 2017 10:22pm |
HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169 |
I just had similar turned out to be both the imoblizer and ignition switch with labour and diagnostics I could have had a nice holiday |
29th Mar 2017 10:21pm |
