Home > Technical (L322) > Another not starting issue, key turns, engine doesn't.
desertdude
United Arab Emirates 2003 Range Rover Vogue 4.4 V8 Alaska White
Initially I thought it was a starter issue, but right I'm pretty sure it isn't. The key turns fine and the car even thinks its switched on as all lights go away and fasten seat belt comes up. I swapped the ignition relay behind the battery, I've even removed the green cap off the relay, switched on the ignition and manually activate the relay contacts by pressing them and still nothing. It doesn't click on its own!
I've even removed the ignition switch module with a little help from weggie here, cleaned it up as per this
Put it back in and still the same. The power doesn't take any load when you turn the key to start, the interior lights don't dim out, not even a sound or hitch from the starter it self, no clicking of weak battery, I've even put in a new battery two days back.
At the moment pretty stumped to what it could be ?
P.S : Have already checked all the fuses too, will check again tomorrow in day time, also doesn't start in neutral either to rule out the inhibitor switch possibility.
P.P.S : Before it totally stopped it did the same and then just started up on it own like normal after a few days, then worked for a few days more and then I use it for like 5 days and has been like this ever since, Its been a month now, since its been acting up now.
Post #429421 27th Feb 2017 4:01pm
Weegie
You found the screws then? Wink
Although cleaning the switch has worked for others, personally, I preferred a new switch (not cheap at about £100).
The other thought is have you tried the Fuse 18 work round? http://www.fullfatrr.com/forum/topic40178.html?highlight=fuse+18
It may not be the switch that is causing the problem. Simple to check and if it isn't that I would plunge for a new switch.
Let's know how it goes. John
GAP iiD BT
Post #429428 27th Feb 2017 4:46pm
Is it possible to put a jump start cable from the starter to the battery just to prove that the solenoid/starter is functioning? Previously..
Post #429431 27th Feb 2017 5:15pm
Suspect starter solenoid not activating, hence no large current draw, you could check for a signal on ignition at the solenoid or just give it a whack, and see if it frees up! There is nothing that can't be fixed with a hammer😜😜
Post #429432 27th Feb 2017 5:29pm
desertdude
@weegie Yeah mate found the screws, would have been impossible to find them on my own the way they are hidden inside, so a big thanks for that, and I do have the key wont turn issue from before but I've bypassed it with a on off switch in fuse 18, so key makes a full turn and would start the car normally. And yeah I'm starting to suspect I might have to get a new one, money is super tight to mention, being out of work and all and the part is on a 15 day waiting list. So was hoping a spit and polish would do the trick.
@Contraband/Northern Monkey, tomorrow I'm going to hot wire the starter to take it off the list of possible suspects for good, although I doubt it is, since the relay doesn't even click
Post #429438 27th Feb 2017 6:29pm
desertdude
Ok so update on the situation, well the starter was duff, had to tow it to a buddys shop where he has a dugout where we can get under the car, a few whack and the car started up, turned on and off a few times but then dead again. Undoing the starter motor wasn't a very difficult job at all, didn't need to open the manifold or anything, but now the dam thing is all loose and wont come out from anywhere, there doesn't seem to be enough space from any side to wiggle it out! Will take out the wheel tomorrow and try from there.
Post #430394 7th Mar 2017 7:10pm
desertdude
OK follow up on the thread.
Had to drop the sway bar to take out the starter from the wheel well. Bench tested the starter and everything seems to be fine ! Exclamation
The solenoid pushes the bendix out, the start churns aways when powered up!
Post #430529 8th Mar 2017 11:57pm
mr_spock
Could it be the immobiliser?
Post #430546 9th Mar 2017 7:44am
StewD
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Any update desertdude ? Current: Supercharged 06 FFRR in Java Black
Previous: BMW 740D M Sport
Previous Previous: BMW 730D Sport
Post #433051 28th Mar 2017 10:22pm
HGv driver
Wales
I just had similar turned out to be both the imoblizer and ignition switch with labour and diagnostics I could have had a nice holiday
Post #433158 29th Mar 2017 10:21pm
