Home > Technical (L322) > Advice / thoughts please on cause of Limp Mode |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 |
Had this with mine and it turned out to be a full DPF - had a new one done under warranty. Don't know if that helps? 2005 L322 Vogue Gold gone
26th Feb 2017 6:19pm |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
Exact same on my TD6. Turned out to be bad fuel and fuel filter. Drained tank, changed filter. All back to normal. Accept, some days your the pigeon, some days your the statue! |
26th Feb 2017 6:22pm |
cgarside Member Since: 25 Mar 2015 Location: Preston Posts: 21 |
Ironically, we were actually setting out on a 70 mile run to get everything warm and cleared out since the car has really only had short journey (less that 11 miles) recently. Am I right in assuming that a long run will clear the DPF or will it need changing?
26th Feb 2017 6:35pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 739 |
possibly split intercooler hose - common problem |
26th Feb 2017 6:38pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7941 |
Intercooler hoses is a distinct possibility on a 3.6 TDV8 - usually hard acceleration though & a message along the lines of Special Programs Off |
26th Feb 2017 8:18pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
I didnt think the 2008 diesels had dpf filters and they were added to later year models! Would check the hoses but they are usually athrow loads of black smoke out of the back at the same time. |
26th Feb 2017 8:24pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6730 |
MY2008s don't have DPF. My money would be on a split hose. Got - 2017 SDV8 Autobiography in Loire Blue
26th Feb 2017 9:40pm |
When the performance dropped off, I checked exhaust and no signs of smoke. Just very limited performance. The five mile journey to get home was done without drama, just went very slowly.
26th Feb 2017 10:41pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
You might need to take the hoses off to see a crack. That has been some people's experience. ______________________________
26th Feb 2017 10:47pm |
Checked hoses and no sign of splits or leaks and as the car has driven fine for the last week or so I have discounted this as the root cause of the problem.
11th Mar 2017 9:41am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8540 |
My money is also on the hoses.
11th Mar 2017 10:22am |
Don't take the warning messages too literally as they are not always accurate.
11th Mar 2017 12:56pm |
OK, so I clearly didn't check the hoses properly.
11th Mar 2017 5:50pm |
Oil in the pipes is pretty normal and nothing much to worry about There is nothing that can't be fixed with a hammer😜😜
11th Mar 2017 7:14pm |
