Home > Technical (L322) > Roy Rangie is running on bump stops
koffeetemple
Australia 2009 Range Rover Autobiography TDV8 Zambezi Silver
Hi Folks
My 2009 pre facelift 3.6 TDV8 (AKA Roy) is coming up with suspension error message and is riding on its bump stops ( more like bump starts than stops)
I assumed it was one of the air bags but when you start the car there sounds like there is air leaking inside the cabin. The AC is off and so is the AC fan.
Can anyone tell me if there an air line attached to the suspension some where in the cabin? I can not hear any leaks outside of the cabin
Thanks for any help with this
Damien Very Happy
Post #429226 26th Feb 2017 9:50am
Did you try searching ?
There's loads of suspension threads Whistle
The air suspension compressor is in the boot under the spare wheel - is it that you can hear ?
If you're getting a specific message, then try searching for that.[/url]
Post #429230 26th Feb 2017 9:57am
koffeetemple
it sounds like it is near the gear shift/dashboard area not from the back
Thanks
Damien
Post #429232 26th Feb 2017 10:05am
mr_spock
United Kingdom 2003 Range Rover Vogue 4.4 V8 Java Black
Locating the source of a noise from inside the cabin is almost impossible. What is the message on the dash?
Post #429240 26th Feb 2017 11:01am
CS
I'd start by checking the compressor/air supply unit, but if you are hearing a noise from the front there is a cross-link valve at the front behind one of the wheel arch covers which might be relevant. Apparently it is a hassle to get at. Only Range Rovers since 1988
Post #429250 26th Feb 2017 12:23pm
Re cross link valve:
It is in FR wheelarch by the mudguard. You can "peel back" the inner wheel arch to gain access without having to take the whole thing off.
Storey Wilson did a video on this:
http://www.rswsolutions.com/index.php/mkii...ir-springs .
Post #429251 26th Feb 2017 12:42pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Mine did this because of faulty height sensor.
I dont understand this 'search' guys.
This is for communication.
Write what u know instead of search advice. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #429254 26th Feb 2017 1:20pm
Not everyone is on here 24x7 waiting to answer your questions - some of the most knowledgeable people may not even still be active members.....
The most effective use of this forum is to search for similar issues people have had - if you can't find an answer, post as specifically as you can - what is the exact message, what have you tried & ruled out etc.
It's very hard to diagnose vague problems remotely Whistle
Post #429259 26th Feb 2017 2:09pm
umitbat
We all try to help and mostly get ideas.
Thanks for interest. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #429319 26th Feb 2017 8:06pm
