![]() | Home > Technical (L322) > TD6 Intercooler Hose again :@ |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
I'll have another look later / tomorrow. Just winding me up as I get covered in oil every time I 'look' at the car!
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Any bearing and transmission specialist should be able to supply you with an 'o'ring.. You say that yours is broken, so you didn't get one in the new pipe? I'd have thought that they'd come with a new 'o'ring... might be worth questioning your supplier.. you might have been sold an incomplete part |
Sorry if I've got confusing, I got the new intercooler pipe October 2016, because of the oil everywhere around it
If it's all there, then a good clean (solvent) and a bit of superglue should see it round again.... looks like you caught it at an angle and it split when it was pushed home, as I said a bit of something to help it slip on will help and a twisting motion will also aid you |
That's if there's only meant to be one seal...
That looks like there should be an 'o'ring on the intercooler stub as well, otherwise there are 2 positions for it to lock in, and because there is a hole in the intercooler stub, if it's not pushed on far enough you'll instantly get a leak from that hole...
Well the 2 reasonable pictures that I have found don't show any hole in the stubbs
Also, as has been commented on before, there is rather a lot of oil.... have you checked the crankcase breather filter..and is it the later vortex type? I'm just wondering if some muppet has drilled that hole to reduce the pressure due to excessive smoke.. which is very common on a BMW engine with a blocked breather! Yesterday I couldn't spell Engineer... Today I are one!
Now it's all making sense!!
Also I changed the breather filter when I did the hose last time, was pretty knackered... bit confused as to where the oil is from as it's dry inside the intercooler pipe |
The oil will be coming from the turbo, but they all loose a bit, but it normally ends up in the engine, so you'd never know! They haven't invented an oil seal that works at 280,000 rpm and exhaust temperatures, so they all weep a mist.
Will see how I get on tomorrow |
I haven't yet no, I couldn't get a hose from local dealer as they couldn't get stock.. ordered another Bearmach one that will probably be here early next week!
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 ![]() ![]() ![]() |
Steve,
