Home > Technical (L322) > TD6 Intercooler Hose again :@ |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
I'll have another look later / tomorrow. Just winding me up as I get covered in oil every time I 'look' at the car!
26th Feb 2017 4:25pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Any bearing and transmission specialist should be able to supply you with an 'o'ring.. You say that yours is broken, so you didn't get one in the new pipe? I'd have thought that they'd come with a new 'o'ring... might be worth questioning your supplier.. you might have been sold an incomplete part
26th Feb 2017 4:37pm |
Sorry if I've got confusing, I got the new intercooler pipe October 2016, because of the oil everywhere around it
26th Feb 2017 5:10pm |
If it's all there, then a good clean (solvent) and a bit of superglue should see it round again.... looks like you caught it at an angle and it split when it was pushed home, as I said a bit of something to help it slip on will help and a twisting motion will also aid you Yesterday I couldn't spell Engineer... Today I are one!
26th Feb 2017 5:16pm |
That's if there's only meant to be one seal...
26th Feb 2017 5:27pm |
That looks like there should be an 'o'ring on the intercooler stub as well, otherwise there are 2 positions for it to lock in, and because there is a hole in the intercooler stub, if it's not pushed on far enough you'll instantly get a leak from that hole...
26th Feb 2017 5:36pm |
Well the 2 reasonable pictures that I have found don't show any hole in the stubbs
26th Feb 2017 5:50pm |
Also, as has been commented on before, there is rather a lot of oil.... have you checked the crankcase breather filter..and is it the later vortex type? I'm just wondering if some muppet has drilled that hole to reduce the pressure due to excessive smoke.. which is very common on a BMW engine with a blocked breather! Yesterday I couldn't spell Engineer... Today I are one!
26th Feb 2017 5:59pm |
Now it's all making sense!!
26th Feb 2017 6:03pm |
Also I changed the breather filter when I did the hose last time, was pretty knackered... bit confused as to where the oil is from as it's dry inside the intercooler pipe |
26th Feb 2017 6:04pm |
The oil will be coming from the turbo, but they all loose a bit, but it normally ends up in the engine, so you'd never know! They haven't invented an oil seal that works at 280,000 rpm and exhaust temperatures, so they all weep a mist.
26th Feb 2017 7:15pm |
Will see how I get on tomorrow |
26th Feb 2017 8:23pm |
I haven't yet no, I couldn't get a hose from local dealer as they couldn't get stock.. ordered another Bearmach one that will probably be here early next week!
1st Mar 2017 10:27pm |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
Steve,
2nd Mar 2017 12:51am |
