Home > Maintenance & Mods (L322) > Sluggish 4.2SC
bluebattery
Sluggish 4.2SC
I was in a mates 4.2SC not so long ago and was amazed at how much of a spring chicken it was. The throttle response was brilliant right from take off. It was a 08MY.
Now mine is a 07MY and while it has the grunt when it's got going the initial throttle response is not as lively and free spinning.
Not sure if the SC is spinning right, if it is just being driven by air or the belt as it should be.
I've got a scheduled all belts, tensioners and pulleys change coming up shortly along with SC oil refresh.
Is there anything else that I need to be looking at? No strange errors on OBD the last time I checked.
Ta.
Post #427972 16th Feb 2017 10:23am
if you replace the pulley with a smaller one then you will find it pick up better.... ... - .- -.
Post #427974 16th Feb 2017 10:26am
bluebattery
Thanks Stan. Which pulley ?
Does that mean the 08 came with a smaller pulley
Post #427977 16th Feb 2017 10:28am
have a read here,
http://www.fullfatrr.com/forum/post414978.html#414978
and here,
http://www.fullfatrr.com/forum/topic14188....ger+pulley ... - .- -.
Post #427979 16th Feb 2017 10:38am
bluebattery
Thank you Stan. That is more a SC pulley "upgrade"
The one I drove had a lot more poke than mine in standard trim.
Just curious to see if I've got a broken element somewhere on my motor which I need to investigate before thinking of upgrades.
Cheers
Sam
Post #427998 16th Feb 2017 2:37pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Sam does your by any chance run lpg? as throttle is a little less responsive when on gas.
Post #428010 16th Feb 2017 4:41pm
bluebattery
Nah mate. On full fat diet.
Post #428011 16th Feb 2017 4:49pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Try pulling the MAF sensor. If it makes no difference, then replace it as that is likely your problem.
Might be worth having any codes read first as I'm sure a dicky MAF sensor would throw a code. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #428012 16th Feb 2017 5:28pm
kyle h.
United States 2006 Range Rover Westminster 4.2 SC V8 Java Black
Probably worth double/triple checking your mates for standard trim, especially if he purchased it used. What you notice in your mates sounds exactly like I would describe mine after the pulley upgrade.
Also, May be worth while searching the jag forums to see if they experience any knock sensor issues.
Post #428512 20th Feb 2017 1:52pm
