![]() | Home > Maintenance & Mods (L322) > Sluggish 4.2SC |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
if you replace the pulley with a smaller one then you will find it pick up better.... ... - .- -.
bluebattery Member Since: 04 Apr 2016 Location: London Posts: 21 ![]() ![]() ![]() |
Thanks Stan. Which pulley ?
have a read here,
Thank you Stan. That is more a SC pulley "upgrade"
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Sam does your by any chance run lpg? as throttle is a little less responsive when on gas. |
Nah mate. On full fat diet. |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
Try pulling the MAF sensor. If it makes no difference, then replace it as that is likely your problem.
kyle h. Member Since: 15 Feb 2016 Location: West Virginia Posts: 23 ![]() ![]() ![]() |
Probably worth double/triple checking your mates for standard trim, especially if he purchased it used. What you notice in your mates sounds exactly like I would describe mine after the pulley upgrade.
