Home > Technical (L322) > Power box |
A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 150 |
Has someone already have instaled a power box to td6?
9th Feb 2017 2:52pm |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
Hi
9th Feb 2017 4:31pm |
come on dolphin boy surely it was in your head was it one of these boxes with the resistor in it that tricks the man to reporting a higher airflow?? |
9th Feb 2017 5:10pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3166 |
No I was very sceptical to start with but did a proper tank to tank mpg calc and it went from 25 mpg to 28 and deffo had a better pulling capability.
9th Feb 2017 6:24pm |
They do work and are proven to work but they are bloody awful devices , as stated all they do is trick the ECU into overfueling usually with nothing more sophisticated than a simple resistor , you get an increase in power along with an increase in soot , fumes and engine wear .
10th Feb 2017 3:36am |
