Home > Technical (L322) > Power box
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Power box
Has someone already have instaled a power box to td6?
It's worth it? Or a remap is better? Here, a home made power box is 30€ and a ramap is 200/300€.
I know that to connect the power box is on the fuel line (common rail) connector which is on the back of the engine.
I've tried to reach it but, without success. There is so trick or special procedure?
Post #427052 9th Feb 2017 2:52pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi
Any of those power boxes are a waste of time and money, they don't really work and at best they trick the engine into over fuelling and giving no more power, anything you feel will be in your head.
If you want an actual torque and power increase the only real way to do it is with a remap by a good company and someone that understand those engines.
Personally any plug in black box is a no no.
Post #427060 9th Feb 2017 4:31pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
I had a Austrian (I think) power box on my td6 and it did improve things slightly, wth better pulling and improved mpg by 2-3 mpg. Think it was called a steuer or something similar.
Post #427067 9th Feb 2017 5:07pm
lighthouse
Rolling with laughter Rolling with laughter come on dolphin boy surely it was in your head was it one of these boxes with the resistor in it that tricks the man to reporting a higher airflow??
Post #427068 9th Feb 2017 5:10pm
Dolphinboy
No I was very sceptical to start with but did a proper tank to tank mpg calc and it went from 25 mpg to 28 and deffo had a better pulling capability.
Not sure how they did it but The proof is in the pudding so they say. Thumbs Up
Post #427082 9th Feb 2017 6:24pm
They do work and are proven to work but they are bloody awful devices , as stated all they do is trick the ECU into overfueling usually with nothing more sophisticated than a simple resistor , you get an increase in power along with an increase in soot , fumes and engine wear .
Get a remap there are plenty of good ones out there and Power boxes are for plumbers in smoking Hilux's who think they can beat a Porsche off at the lights(oh erh ) Rolling with laughter 2008 MY Supercharged
Post #427127 10th Feb 2017 3:36am
