Home > Off Topic > Apple Mac book pro help ?
verydisco
Hi. Any MBP 17'' expert here ? Mine went in kaput mode today. Very oddly it works with the external display but when I unplug the display the MBP screen freeze. Without a display plugged in It will boot, let me log in then freeze.
The motherboard was replaced just over a year ago, then the batt 2 weeks ago. it has a 1t SSD and a 2t harddrive. I have been trying to keep it running as they do not make 17 anymore. I tried PRam and SMS etc. Not found of the newer one so would really love to fix it. Help guys. (Y) l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #426642 6th Feb 2017 10:21pm
ajac8
HI
Did you get any pixellation before it went bang? If so could be the GPU card. I've heard of these working on external screens whilst the 'home' screen chips are done for. Cant be certain but might be worth a bit of googling.
Similar thing happened to my i5 mac. In my case it was a 10 minute blast in the oven to soften the solders and reinserted the card. 12 months later still flying! Not sure if this solution still works for a MBP. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #426661 6th Feb 2017 11:50pm
Jambo
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Might be worth running a program called DiskWarrior (by Alsoft). If it is software related this is the program to sort it!
Presume you're running a recent version of OS and have tried repairing disk permissions etc?
Good luck.
Post #426664 6th Feb 2017 11:59pm
Not much help but the 17" pro is the only duff Mac I have had in 20 years , motherboards and hard drives seem to always go pop too soon . 2008 MY Supercharged
Post #426676 7th Feb 2017 2:23am
RR2008HSE
My first suggestion would be: use an external monitor and external HD to get everything off it while you can. Hardware is fixable, but data recovery is long, expensive and not always successful. Good luck.
Post #426767 7th Feb 2017 8:33pm
mr_spock
Which model MPB? Late 2010/some 2011s have GPU issues, although when mine went it just wouldn't boot with or without an external monitor. Apple still has a free repair programme back to (I think) early 2011s.
Post #426880 8th Feb 2017 3:28pm
Emperor Mong
I had this too. MBP 2011
Post #427108 9th Feb 2017 11:03pm
GPMG
England 2004 Range Rover Vogue Td6 Epsom Green
Yes and me
Post #436194 28th Apr 2017 8:47am
mpirie
Not sure if this will help but both my MBP 13 and 15 will not boot if there are devices plugged into the USB ports.
Solution is to unplug everything except power and reboot so when you see the Apple at startup, plug your USB devices back in.
Mike
Post #436206 28th Apr 2017 9:45am
