Home > Maintenance & Mods (L322) > Blown turbo
dolph34
 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #426785 7th Feb 2017 8:30pm
dolph34
Turbos back and rebuilding will commence , also had handbrake module changed, rear suspension dropped necessitating cutting out a seized drop link and discovered a bent rear caliper slider. The fun continues!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #426787 7th Feb 2017 8:33pm
dolph34
Car collected today and all good except for the james bond style.smoke.screen for about 10 miles. Tracking done and aircon regassed.
Small issue with the air suspension. When i collected the car , tthe offroad screen showed the the front right wheel was lower than the others. Iid tool used and height measurement mechanism was not working. Quick inspection and plug was not fully seated so a big push and all good EXECPT when using the switch ( 07 model ) flashes to show downward movemnt 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #427053 9th Feb 2017 3:30pm
dolph34
Screen froze, movement but it also flashes downward when the car is rasing.
Again air suspension perfect just switch flashes down for all movements up or down. Any thoughts ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #427054 9th Feb 2017 3:32pm
rar110
Good news that it's mainly fixed. Also good to know the turbos can be economically rebuilt.
Sorry can't help either EAS issue.
I'm assuming the black smoke was oil residue in the exhaust. ______________________________
Post #427101 9th Feb 2017 9:14pm
dolph34
Thanks, it was oil residue from the exhaust but it was white smoke and no joking , Bond himself would have been embarrassed. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #427106 9th Feb 2017 9:40pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
Good to hear you have it back on the road and hopefully the other problems will be easily sorted.
I changed the turbo on a Kia a while back and was annoyed because I ended up having to take the manifold off too, thanking my lucky stars now.
I think I used these guys and found them good.
http://www.turbo-service.ie/
Post #427164 10th Feb 2017 12:53pm
dolph34
Thats who i used , adam was the guys name. They are only 5 mins from me.
Quick turnaround and good price. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #427189 10th Feb 2017 3:34pm
dolph34
I see your close to me , i have a reconditioning kit for a Hitachi ( the one fiited to the 02 -08 cars i think ) air compressor, i found out i have the later compressor fitted so the kit is going free if its any good to you.
Just pm and its yours 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #427191 10th Feb 2017 3:37pm
hamlet
You are very good sir, I do hear mine buzzing away and often meant to time the operation to see if it's on the way out so I'll take you up on that, PM on the way, thanks...... Thumbs Up
Post #427194 10th Feb 2017 3:51pm
dolph34
No problem Very Happy 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #427201 10th Feb 2017 4:09pm
