Home > In Car Electronics (L405) > L405 Rear Seat Entertainment & iPad Integration... |
iconoclast Member Since: 20 Oct 2015 Location: In, Out & Around... Posts: 35 |
Attempting to utilize archaic technology with current technology.
1st Feb 2017 9:47pm |
I used exactly that cable to stream videos from an old IPOD into a 2007 VSE which has different RSE. Still have the cable some place but not seen a lightning version of it yet.
1st Feb 2017 9:52pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1403 |
1st Feb 2017 10:23pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
I use a wireless flash drive and stream films to the ipads from that.
2nd Feb 2017 10:07am |
w8pmc Member Since: 30 Oct 2016 Location: West Lancashire Posts: 229 |
Can you explain that Wireless streaming to an iPad in more detail?
2nd Feb 2017 11:20am |
Not ours... it is an older device. I don't recall which it version it is but it uses the traditional rectangular plug.
our Q7 has built-in in wife and we have no difficulty streaming video on the go... we anticipated a few issues in the mountains but outside of some minor buffering we did not come across any real problems. we download most of the movies however space limited because of the other applications and data stored on the device and even when downloaded we still would like to display the video into the headrest as opposed to the iPad. https://instagram.com/_.iconoclast/ |
2nd Feb 2017 1:21pm |
If you have existing films on a portable hard drive you can buy the Kingston Mobilelite Wireless hub. This has an internal battery and can power external hard drives and SD cards. It then creates a mobile hotspot you can log into from the ipad, or any phone/computer with wifi. I have the G2 but there is a newer G3 model out. For small simplicity you can use a SanDisk Connect, this has internal memory and takes SD Cards on top. Has a 10 hour battery life but can be charged when in use by USB. My original solution was to use a hard disk with wifi built in so have a Seagate Wireless Plus 1TB and that works well too, but obviously does not take SC cards on top. All options are relatively cheap and work well. I like the fact that they can be accessed by multiple devices all watching different things. Tom Current Drive 2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather Previous Drives 2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather 1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather 1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic |
2nd Feb 2017 1:53pm |
Excellent! Thank you very much, I truly appreciate the help. https://instagram.com/_.iconoclast/ |
3rd Feb 2017 9:57pm |
Glad to be of help.
4th Feb 2017 9:15am |
Hahaha... AutoCorrect. WiFi. https://instagram.com/_.iconoclast/ |
5th Feb 2017 3:47am |
