Home > Technical (L322) > Suggestions for contact cleaner |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 |
I know the advice is not ever to disconnect electricals in the ff, but what is the best stuff for cleaning the pins and connectors if it cant be avoided and you want to avoid the gremlins coming out to play when you re-connect everything? QUID FACIUM TIBI
31st Jan 2017 8:00pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I use WD40 specialist fast drying contact cleaner, it's grrreat ! |
31st Jan 2017 8:33pm |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 351 |
Electrolube EML contact cleaner lubricant.
31st Jan 2017 8:44pm |
