Home > In Car Electronics (L322) > 2004 Satnav screen Failed - what are my options? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Bit confused - what is the difference between the "monitor" and the "SatNav Head Unit Display" ?
30th Jan 2017 12:41am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6734 |
2 words - Garmin and TomTom Got - 2017 SDV8 Autobiography in Loire Blue
30th Jan 2017 9:02am |
2 better words. Cellphone and Waze |
30th Jan 2017 10:36am |
RSWilson Member Since: 27 Mar 2016 Location: East Yorkshire Posts: 33 |
Hi all,
30th Jan 2017 12:36pm |
mullymoo Member Since: 24 Jan 2017 Location: isle of wight Posts: 8 |
got the same issue...have a wee look at the blue connector pins on the tv module... |
31st Jan 2017 6:06pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 871 |
I've got a brand new lcd screen that if you're sure its the screen at fault, I'm open to offers on. |
31st Jan 2017 7:09pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8304 |
http://www.fullfatrr.com/forum/topic27033.html
31st Jan 2017 8:22pm |
Thanks to everyone who has replied here. I have just been out for a poke around the wires and i can't see anything untoward at the rear of the head unit. It is raining out there but i couldn't see the corresponding cables in the rear compartment. Do they plug into the rear of the satnav unit?
31st Jan 2017 9:16pm |
Just a brief update. I checked all the plugs and sockets i could find and they are all in good condition. I put it all back together but it still didn't bring the monitor back to life. Then we went for a bool and after about half an hour it started to flicker and slowly came back to life! It still flickers but its is fine in the main.
5th Feb 2017 1:15pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Did you remove the sat nav unit from its mounting and check the two plug / socket pins on the rear of it? If you didn't I would.
5th Feb 2017 1:42pm |
Yes i removed the 3 x 10mm bolts and removed the satnav player. It was all dine however initially i hoped to see a problem because there was a tiny hint of a rust discolouration on the rear of the satnav player. When i pulled the plugs they were perfect and i looked at the screen as i wiggled and plugged these but there was no effect to suggest it was the cause.
5th Feb 2017 2:05pm |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
Check the blue connector to the tv tuner in the back. This was what was causing my screen to randomly go off. No7 - 2003 V8 Vogue |
7th Feb 2017 5:39pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
You can thank me later 🤣
23rd Feb 2017 8:40pm |
Hi Folks, I lived with this issue since reporting it but I bit the bullet and bought a Mk4 GPS DVD player.
17th May 2018 8:16pm |
