![]() | Home > In Car Electronics (L322) > 2004 Satnav screen Failed - what are my options? |
Bit confused - what is the difference between the "monitor" and the "SatNav Head Unit Display" ?
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
2 words - Garmin and TomTom |
2 better words. Cellphone and Waze |
RSWilson Member Since: 27 Mar 2016 Location: East Yorkshire Posts: 33 ![]() ![]() ![]() |
Hi all,
mullymoo Member Since: 24 Jan 2017 Location: isle of wight Posts: 8 ![]() ![]() ![]() |
got the same issue...have a wee look at the blue connector pins on the tv module... |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 888 ![]() ![]() ![]() |
I've got a brand new lcd screen that if you're sure its the screen at fault, I'm open to offers on. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
http://www.fullfatrr.com/forum/topic27033.html
Thanks to everyone who has replied here. I have just been out for a poke around the wires and i can't see anything untoward at the rear of the head unit. It is raining out there but i couldn't see the corresponding cables in the rear compartment. Do they plug into the rear of the satnav unit?
Just a brief update. I checked all the plugs and sockets i could find and they are all in good condition. I put it all back together but it still didn't bring the monitor back to life. Then we went for a bool and after about half an hour it started to flicker and slowly came back to life! It still flickers but its is fine in the main.
Did you remove the sat nav unit from its mounting and check the two plug / socket pins on the rear of it? If you didn't I would. |
Yes i removed the 3 x 10mm bolts and removed the satnav player. It was all dine however initially i hoped to see a problem because there was a tiny hint of a rust discolouration on the rear of the satnav player. When i pulled the plugs they were perfect and i looked at the screen as i wiggled and plugged these but there was no effect to suggest it was the cause.
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
Check the blue connector to the tv tuner in the back. This was what was causing my screen to randomly go off. No7 - 2003 V8 Vogue |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
You can thank me later 🤣
Hi Folks, I lived with this issue since reporting it but I bit the bullet and bought a Mk4 GPS DVD player.
