Home > General > DIY FBH |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
It was -10 in Cambridge today and I thought I was going to rip the door handle off trying to open it this morning.
20th Dec 2010 9:32pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
seen a local chappy do this with his volvo estate - works a treat 3kw fan heater in the boot |
20th Dec 2010 9:36pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 |
This is common in Scandinavia where cars have a 240V block heater, all the hire cars have a little mains fan heater in the passenger footwell |
20th Dec 2010 9:44pm |
I believe you can get a block heater for the Jag engine? Then you just plug in every night with a weatherproof socket by the tow bar or something... run it on a household timer to kick in an hour before you set off in the morning... |
20th Dec 2010 9:46pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35459 |
interesting, but it wouldnt work if you lived at the top of a block of flats [unless you had a very long lead]... ... - .- -.
20th Dec 2010 9:50pm |
Who owns a Range Rover and lives in a block of flats? And surely if that was the case it would be a cheap oil burner with the FBH fitted as standard anyway! |
20th Dec 2010 9:53pm |
The other benefit is telling everyone you have an electric RR
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 |
Err... I do... |
20th Dec 2010 10:09pm |
Really? How quaint. |
20th Dec 2010 10:26pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
dantheman going come back now and tell you its a penthouse in kensington.. For flat owners http://www.dry-it-out.com/inverter-5006-3k...-free-fuel dont tell your insurance company... 2004 black Vogue TD6 |
20th Dec 2010 10:43pm |
20th Dec 2010 10:58pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
My Cheap Oil burner doesn't have a FBH fitted, unless I'm missing something!
20th Dec 2010 11:10pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
I've done the fan heater trick in my van a few times, it's a LWB Vivaro with no bulkhead so when it gets cold, the van is really cold, all the heater does is push the warm air to the back of the van and forces the cold air forward.
21st Dec 2010 12:59am |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Overkill? You can have a air FBH installed (rather than water as in the RR). Both of the big FBH manufacturers, Webasto and Eberspacher, make them. Price for the kit is roughly the same as with a water FBH but the install is generally a bit quicker.
Ahh, but I pay €1.15/L filling up yesterday, grasshopper. That's GBP 0.97/L at this mornings exchange rate. Full tank only cost me an equivalent of GBP 83.- . If you'd have been at the pump next to me, you'd have payed 1.39 or GBP 1.18 = GBP 118,15 for the same amount of fuel. And LPG is a good 25 km drive out of my way - 50km there and back. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
21st Dec 2010 7:25am |
