![]() | Home > Wheels & Tyres > 255/55R20 on a 2008 SC L322? |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I have 265/60/18s which are bigger, and they don't rub. 275/55/20 will unless lifted I believe. ______________________________
d00d Member Since: 11 Jan 2016 Location: Pacific Northwest, USA Posts: 55 ![]() ![]() |
By my calculations:
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
255/55/20 rub lol never heard such bull, loads of us use them and a far better ride and loads of room still |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1464 ![]() ![]() |
![]() ![]() Thank ![]() ![]() If your standard 255/50R20's aren't showing at least a couple of inches clearance in the wheel arch then you probably have an issue with your air suspension ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Suspension works fine, room around the arch looks plentiful, I'd just been worried about bits touching on the inside of the well when the wheels were turned hard, but sounds like that's not a problem, woohoo! Thanks all! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Quite a few of the folks on here have started running the as they are an increasingly common size from the l405. Not heard any issues as yet. There is nothing that can't be fixed with a hammer😜😜
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
buy them ,fit them ,no problems |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
I removed my 255/50/20s for 255/55/20s the new tyres were from an L405.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
Sorry to hijack but those that have fitted them do you notice a difference in the handling it is just that I run 19 on 255 55 for winter and compared to summers on 20 255.50 it feels less firm
@Sandyt - took awhile but I finally got around to getting them fitted. First thing I noticed was the 2.5cm height difference is definitely noticeable, "riding taller". (Maybe more like 3cm for how bald the old ones were!)
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3260 ![]() ![]() ![]() |
What pressures are people running 255.55.20s on? John
As long as other conditions (weight, distribution, road surface, contact patch) aren't changing, you'll most likely want run exactly the same. 2008 SC L322
? same as what 255.50.20s? John
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1403 ![]() ![]() ![]() |
That is what I have been doing, 33 front & 36 rear, Goodyears on 405 style 502 wheels, pleasant comfortable ride. Only Range Rovers since 1988 |
